Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Aftermarket ignition leads for Mk4(facelift) Fiesta with the 1.3 Endura E lump
Old Apr 22, 2014 | 12:35 AM
jduck1979's Avatar
jduck1979
Petrolhead reborn
Default Aftermarket ignition leads for Mk4(facelift) Fiesta with the 1.3 Endura E lump
Anyone know what'll fit?
Application lists from lead manufacturers such a Lumenition / Splitfire / Magnecor, etc list lead sets for the Ford Ka with the same Endura E lump under the bonnet, but don't say if they'll fit the Fiesta as well (e.g. same length, different fitting at one end).
I was thinking of the Lumenition ones from Demon Tweeks, but not 100% sure as the longest one they do (36" / 914mm) might be 16mm too short going by the measurements of a set of regular leads for my car off Eurocarparts.
Already tried to find info on this from 3 other forums since Sunday, but still none the wiser
Only had the thing since 10th April - bought with 52,427 miles on the clock and "2 careful lady owners", so still in the process of catching up with routine maintenance tasks on it that've been neglected (e.g. may have been driven carefully, had work done on it to get it through the MOT + oil changes..... but still appears to have the original plug leads + when I checked the pollen filter on Sunday afternoon it looked like you could grow a salad garden in it... haven't checked air filter yet, as I don't have the right Torx bit to get into the housing).
Old Jun 29, 2014 | 07:43 PM
Oranoco's Avatar
Oranoco
No point to them at all, just buy a good quality stock lead.
Old Jul 25, 2014 | 10:59 PM
JoeyBoyden's Avatar
JoeyBoyden
Yeah as said above waste of time. Same with plugs, don't bother on aftermarket things like that especially on this engine, I have the same engine and felt negligible gains from Ultimate plugs and crap like that. Just invest in a decent set of OEM plugs and leads
Old Jul 26, 2014 | 10:28 AM
philip59's Avatar
philip59
Dick Whittington
Default 10mm HT leads
See formulapower.com and type in FP701 which is the set for your car.
Thanks Philip
02088969172
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
sunburstred
Sep 9, 2015 11:24 PM
imnoteasy
Sep 7, 2015 09:26 PM
chris m1
Sep 7, 2015 08:02 PM
