Crank case breather
Old Apr 20, 2014 | 09:36 PM
marky_g's Avatar
marky_g
Fleet Manager
Default Crank case breather
In the pic is this correct the breather vents from the crank case and also a pipe on the manifold? will this not cause a boost leak as there dose need seem to be a one way valve or anything
Old Apr 20, 2014 | 11:12 PM
reithy's Avatar
reithy
There's normally a one way valve in the small hose, but the breather pot looks right, should have a hose that goes back to the airbox
Old Apr 21, 2014 | 07:46 AM
marky_g's Avatar
marky_g
Fleet Manager
There's no longer an air box so it'll be atmosphere vented I just need the 1 way vale then
Old Apr 21, 2014 | 01:21 PM
Rich87's Avatar
Rich87
Yeah just need a one way valve I've just got one node eBay make sure you don't drove on boost until you get one tho as this can cause big damage to your piston rings and cause the filler cap to blow off and splat oil all over the engine bay
Old Apr 21, 2014 | 03:47 PM
marky_g's Avatar
marky_g
Fleet Manager
The guy wiring on the cars gonna blank it off, you got an item number for the valve?
Old Apr 27, 2014 | 12:48 PM
Rich87's Avatar
Rich87
Item number is 130974315888 I got the 6mm valve but it's a bit small probably better off with the 8mm
Nov 1, 2015 06:53 PM
muz
Sep 30, 2015 08:29 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Flatlinedan
Sep 18, 2015 12:41 PM
