Ford Puma Discuss the Ford Puma here!
1.7 clutch change advice please
Old Apr 17, 2014 | 02:55 PM
Jessop's Avatar
Jessop
Default 1.7 clutch change advice please
Hi, my clutch has started slipping every now and again so at a guess I'd say the slave cylinder is leaking? Would a Fiesta 1.2 clutch fit? I have one in the garage so would save me money if they are the same.
Thanks
Old Apr 17, 2014 | 09:12 PM
STeve's Avatar
Super Moderator
unless your losing brake fluid then chances are your slave cylinder is fine, more like a worn pressure plate, when some mates did mine they found my flywheel was badly grooved which needed skimming, and I would say a 1.2 clutch wont fit
Old Apr 20, 2014 | 03:32 PM
Jessop's Avatar
Jessop
Hmm never checked my brake fluid. Have got a brand new clutch and cylinder now anyway so will have to just let my mate do his magic now
Old Apr 21, 2014 | 06:44 AM
STeve's Avatar
Super Moderator
well if your brake fluid has not dropped I would bet the slave is fine
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
rex647
Mar 6, 2022 06:20 AM
yatta
May 21, 2016 10:31 PM
RSBryden
Sep 6, 2015 08:39 PM
kevin36
Sep 2, 2015 06:24 PM
