sapphire cosworth 4x4 mastercylinder help
Old Apr 11, 2014 | 09:32 PM
matthewpickup's Avatar
matthewpickup
Default sapphire cosworth 4x4 mastercylinder help
hi all wondering if anyone knows which brake pipe dose front brakes and which goes to the rear axle?
the master cylinder has numbers on it next to the pipes 1,2,3 ...
I am not using the abs unit so would be great if someone knew which pipe went where ?
thanks for your help
Old Apr 11, 2014 | 10:02 PM
James @ M Developments.'s Avatar
Iirc, one of the 3 is the return from the abs block, one outlet is front, one is rear, they can be tee'd as that's what the abs block does.
Old Apr 11, 2014 | 10:11 PM
matthewpickup
thanks for the reply , I am confused now as I have just read from another thread that 1- N/S front 2- rear 3- O/S front
Old Apr 11, 2014 | 10:14 PM
It was an age ago I did mine so I might be wrong but I'm sure only 2 give fluid, one is just a port straight back to the reservoir for a fluid return
I blocked that one off when I ditched the abs
Old Apr 11, 2014 | 10:18 PM
matthewpickup
well tbh you sound right as I don't think you would block off one giving fluid out so I guess I will just have to pipe it up and see what 2 outlets is pushing fluid out , but thanks for your help
Old Apr 12, 2014 | 09:50 AM
cossie moon's Avatar
cossie moon
Durham RSOC member
All 3 supply fluid. All 3 go to abs block. Then them 3 supply brakes 1o/s front 1 n/s front and 1 rear which is t-pieced on rear of car to do both rears.
Old Apr 16, 2014 | 10:16 PM
matthewpickup
thanks for the replies but looks like I will need to work it out so I know one way or another lol , will post my findings to help others later
Old Apr 24, 2014 | 09:27 PM
matthewpickup
hi all , its as James said two feed and one return the middle outlet is a return
SmudgerByName
52
Jul 28, 2016 06:14 PM
3dr cossie
11
Dec 21, 2015 03:38 PM
lukeeboy149
Aug 22, 2015 04:29 PM
cossie4x4
Aug 14, 2015 06:29 PM
yawiejon
Aug 10, 2015 08:12 PM
