mondeo mk3 tdci just turns over wont fire
Old Apr 7, 2014 | 02:43 PM
jason1987's Avatar
jason1987
Default mondeo mk3 tdci just turns over wont fire
Hello pleass can anyone help got a mondeo tdci car just turns over will run on easy start but won't take over its self and run on diesel had fault codes read and this is what I've come up with
P0190
P1211
P2291
P0251
P1283
Checked wiring connectors at fuel rail and pump with electrical tester and there's no power to then
Be grateful of anyone who can help
Old Apr 7, 2014 | 03:07 PM
Cardie's Avatar
Cardie
Any diesel will run on easy start as long as the engine is spinning over quick enough.
Have you had any starting or idling problems recently or has this just happend? Whats the milage?
Old Apr 7, 2014 | 10:11 PM
jason1987's Avatar
jason1987
Went through some water it cut out dint hydro lock got it recovered home took injectors out turned engine over some water was in engine got it out sent injectors off for bench testing two were blocked got them sorted put back in getting fuel to 1 and 2 injectors but nothing to 3 and 4 just bubbles then got them codes but theres no power to pump injectors or rail wiring runs to ecm which could of got wet I guess just don't want to sell car there's no swarf in filter checked that no fuses are blown either
Rob Wells
Apr 18, 2023 12:19 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
Bighandsuk
Sep 2, 2015 05:23 PM
