Rust :-/
Old Apr 4, 2014 | 09:07 PM
KW-rscos's Avatar
KW-rscos
Default Rust :-/
Hi guys,
I stripped out the saph today getting ready for new sills and rear arches, only to come across this in the drivers footwell:
Is this fixable or terminal?
Many regards,
Kieren
Old Apr 4, 2014 | 09:12 PM
cossiestu's Avatar
cossiestu
Is the first pic the outer seat mount? If so, mine was like that, my mate welded a plate over it, I'm sure the tunnel area can be cut out and a plate welded in....?
Hope you can sort it easily!
Old Apr 4, 2014 | 10:00 PM
KW-rscos's Avatar
KW-rscos
Yeah it's the outer seat mount.
Well I would love to fix her, but weighing up the options at the moment, reshell may be an option, just really like this car?!
Old Apr 4, 2014 | 10:28 PM
cossiestu's Avatar
cossiestu
Can't remember exactly how he did it, but my mate didn't have any real trouble welding the seat mount area back in... I fear mine is going in the footwell area too, just not as bad as yours! ....I hope!!!
You must surely be able to get a repair panel to do the footwell, even if you have to pay someone to weld it in (I can't weld for shit, so that's what I'd have to do!!) it would be easier than re shelling it, unless the rest of its rotten like that underneath!?
It's not GOT to be mega neat, so maybe you could hire a mig welder an have a bash yourself!?
Old Apr 4, 2014 | 10:46 PM
stu20004x4's Avatar
stu20004x4
mk6 escort fantasist
if your getting sills and arches done already, you may aswell throw the bit extra towards these other bits. either that or cancel the bodyshop and buy a kit to try your hand at it yourself. practice first though! atleast if you find you cant do it, you can flog on the welder etc with minimal loss and then decide what to do.
cue someone from a bodyshop to come on saying your mad to try it yourself, cant beat a professional job rah rah, if you have the time and patience ro learn how to do it and do it properly, the only difference will be the amount of time it will take (considerably longer) and momey (considerably less)
Old Apr 4, 2014 | 10:47 PM
Dezzer's Avatar
Dezzer
4x4 resto
Hi , my sapph went in exactly the same places and we cut out the rot then made some repair pieces to fit , its quite time consuming , you will find its double skinned on the tunnel so we had to repair both skins but it can be done
Old Apr 5, 2014 | 04:33 AM
Just get the grinder out and and chop the rot out. Saffs need saving not scrapping.
Old Apr 5, 2014 | 10:11 AM
Tinshaw's Avatar
Tinshaw
Ayup fella.
Mine was exactly the same I hadn't got a clue about welding either!!!! My mate had done a bit so we just got the grinder out & cut all the rot out the took our time cutting & shaping everything so when it was welded it looked like a factory finish, the tunnel was the hardest as it was double skinned, & shaped all different ways but now it's all painted u would never tell. As I'm a tad fussy about things looking right.
Old Apr 5, 2014 | 10:42 AM
KW-rscos's Avatar
KW-rscos
Thanks for the replies guys, it's reassuring to know that this isn't terminal!
Although I am surprised that you can't get the floorpan as you can get all sorts for the mk1+2 escorts, hey ho, the joys of old ford ownership :-/
Old Apr 5, 2014 | 08:27 PM
Paul_RS's Avatar
Paul_RS
Those are common rust areas unfortunately. Worth saving though!
Cosworth's are getting old enough now that they'll be able to be used in rallies etc again soon. I think we'll see lots more panels being remade when people can compete in them again.
Old Apr 6, 2014 | 06:31 AM
Ridgey's Avatar
Ridgey
Let's hope so
Old Apr 6, 2014 | 07:35 AM
Moonstone Mart's Avatar
Moonstone Mart
EBay item 251034001119 cover that part of the floor?
They have both sides for sale too but not cheap.
Old Apr 7, 2014 | 06:42 PM
tosh's Avatar
tosh
If you have got the time and patience buy a mig welder and have a go yourself as said above practice on some scrap first, to cut mine I used a dremel with the speed click 38mm cutting wheels on the end of a flexy shaft takes a little bit longer than a grinder but gives a more accurate cut in tight areas.
here is a few pics of my first attempt
Old Apr 7, 2014 | 07:49 PM
Mark V8's Avatar
Mark V8
Get stuck in with a grinder
Old Apr 7, 2014 | 07:50 PM
johnnycortina's Avatar
johnnycortina
Thats very tidy work there
Old Apr 8, 2014 | 02:40 PM
Some top work there matey.
Old Apr 8, 2014 | 04:13 PM
KW-rscos's Avatar
KW-rscos
Hmmm, might actually attempt this!! I have a grinder, can buy a welder, couple of questions though,
What can I coat the metal work in to stop it reoccurring?
Also my seat anchor is very close to the chassis number, what options do I have if the rust is under that?
What's the easiest way to get the sound deadening up with?
Old Apr 8, 2014 | 04:37 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
That's looking really good, well done
Old Apr 8, 2014 | 07:09 PM
tosh's Avatar
tosh
I ground back to bare metal after cutting away the rusty bits and then spray everything with a weld through primer inside and out before welding.
Old Apr 9, 2014 | 02:27 PM
KW-rscos's Avatar
KW-rscos
Tosh, will that stop it rusting again? Mark what did you coat yours with?
Some really good looking work there!! Mark, with a standard grinder how did you not go through the jacking point etc on the outside?
Old Apr 9, 2014 | 08:50 PM
Mark V8's Avatar
Mark V8
I used these, they are fantastic considering how thin they are.
http://www.screwfix.com/p/flexovit-u...ack-of-5/71334
Next to no distortion when cutting as they make hardly any heat.
I did go through the jacking point a tiny bit as you can see the small slit in this pic.
I just welded it up and ground it smooth, I also built up the area around the jacking point hole with weld and spent ages with a dremel smoothing it out.
On the inside of the panels that are not accessible after welding I used weld through zinc primer from Halfords
http://www.halfords.com/webapp/wcs/s...egoryId_165625
Once the whole car is painted I'll drown all the cavities in dinitrol
http://www.rust.co.uk/products/produ...hs-cavity-wax/
All bare metal that I could get to after welding I used epoxy primer
http://www.rust.co.uk/products/categ...y-body-primer/
After that I used epoxy chassis paint
http://www.rust.co.uk/products/categ...chassis-paint/
After sanding more primer, then top coated with two pack.
With hindsight I should have used the epoxy chassis paint first and then used epoxy primer over the top.
Old Apr 9, 2014 | 09:34 PM
KW-rscos's Avatar
KW-rscos
Bloody hell, smart job! Thank you for all the links etc, very much appreciated.
Old Apr 10, 2014 | 05:12 PM
Mark V8's Avatar
Mark V8
Tosh made a good point when he said about using a dremel on the tunnel.
It's really difficult to get into the tight corner with a regular grinder, dremel takes a while but does a neat job.
Old Apr 10, 2014 | 05:18 PM
daz1968's Avatar
daz1968
Dremmel is very good I used one to cut out inner wing behind the strut top, nothing else would have got in there.
Also jotun 87 is similar to epoxy mastic as above and a lot cheaper
Old Apr 11, 2014 | 01:59 PM
tosh's Avatar
tosh
Totally agree! You would be surprised how good a dremel with the 575 angle attachment is, and with the speedclick cutting disc's it makes a great mini grinder and cuts thin metal pretty quickly.
Old Apr 11, 2014 | 02:02 PM
tosh's Avatar
tosh
Mark V8 I bow down to your work mate, what a great finish.
Old Apr 12, 2014 | 09:14 AM
KW-rscos's Avatar
KW-rscos
Hi Mark, what did you guys use to get back to bare metal?
Tosh, what metal did you use for your plates?
Old Apr 12, 2014 | 02:33 PM
Mark V8's Avatar
Mark V8
I bought the cheapest, nastiest electric drill that B&Q sell and used these.
http://www.ebay.co.uk/itm/24pc-Wire-...ht_2543wt_1161
It buggers the drill up fairly quickly so you just take the broken one back and exchange it for a new one
Old Apr 12, 2014 | 06:02 PM
Paul_RS's Avatar
Paul_RS
Want to do the underside of mine Mark?
Old Apr 12, 2014 | 08:07 PM
tosh's Avatar
tosh
I was recommend to use zintec coated steel I think it was 1mm great stuff had it lying around for ages and didn't rust, if it's for structural parts you would probably need thicker.
Old Apr 12, 2014 | 09:14 PM
KW-rscos's Avatar
KW-rscos
Excellent, thanks guys.
Old Apr 12, 2014 | 10:26 PM
Mark V8's Avatar
Mark V8
Once in a life time is enough to be honest
Old Apr 13, 2014 | 12:23 PM
Paul_RS's Avatar
Paul_RS
Not even if I throw in a packet of Skittles?
Your's has to be one of the best shells about by now
Old Oct 23, 2025 | 05:37 PM
nixon_2wd's Avatar
nixon_2wd
Hi guys,
Attachment 61981
Attachment 61982
Many regards,
Kieren
Hi guys, I make new reinforcement brackets for this exact purpose. Made from 1,5mm steel identical to the original stamping, but with superior material quality.
They come in pair with proper square weld nuts. £120+28 shipping to Britain from Norway.
Ideal for your restoration.
Best regards
Andreas
Nov 1, 2015 06:53 PM
