St 170 wheels
Hi Guys
I run a 2wd sapphire cosworth and am looking to upgrade to 17" wheels so I can fit bigger brakes
I have been offered a set of St170 wheels , Will these work on a cossie as regards offsets etc
Also I am still after a Aircon wiring loom to fit my other cossie which is a 93 4x4 if any one has one.
Cheers Tim.
Cheers Tim.
Dont do it. I have tried some 17" Focus Duvall (called overhere) wheels and they have an offset of 49. Should be around the same offset as the ST170 ones. That puts the alloy really too much inside the arch.
Adam Graham
Sep 6, 2015 06:04 AM
