Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Ford fiesta 1.8 Diesel 1993 heavy vibrations
Old Mar 30, 2014 | 09:22 PM
Amigaboy's Avatar
Amigaboy
Default Ford fiesta 1.8 Diesel 1993 heavy vibrations
So my girlfriend is using a ford fiesta diesel for her daily commute to work and home . The car works like a charm except the vibrations in the interior are brutal, the dash and the shifter vibrate really alot. The engine itself is quite , starts right up , no problems at all , except for the brutal vibrations in the interior...I have visually inspected the engine monts and they look ok.. So is there anything I should check , is there a mount that fails but looks normal, any help would be appreciated , so that I could kill the vibrations of the interior.
Thanx in advance.
Old Mar 31, 2014 | 05:19 PM
reithy's Avatar
reithy
When the engines on tick over in the engine bay is it vibrating?
Get your misses to put it in gear and pull it up to the bite point, look and see if it moves more on one side.
Botts
Aug 13, 2015 04:16 PM
taylora1409
Aug 12, 2015 12:06 PM
