Size of pipe internal dia to fuel reg
Old Mar 27, 2014 | 04:23 PM
capri280's Avatar
capri280
Default Size of pipe internal dia to fuel reg
Hi folks
Need your help
What is the internal diameter of the short piece of fuel pipe that goes from the fuel rail to the fuel regulator.
Old Mar 27, 2014 | 05:17 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
8mm as I recall
Old Mar 27, 2014 | 05:34 PM
opposite lock's Avatar
opposite lock
I just measured my 2wd weber (old o.e) fuel inlet pipe its 5mm OD if any use. 8mm sounds right . Return is 7mm OD just for reference.
Old Apr 13, 2014 | 03:22 PM
capri280's Avatar
capri280
Thanks
Old Apr 13, 2014 | 04:07 PM
RSMK4TURBO's Avatar
RSMK4TURBO
This maybe of help....
http://www.burtonpower.com/fuel-regu...-yb-sc533.html
s1cab
Jul 26, 2018 06:11 PM
ekjim
Aug 27, 2015 05:20 PM
muffster
Aug 12, 2015 08:14 PM
