What bhp is the limit using standard zetec valves ?
Old Mar 26, 2014 | 07:01 PM
s1cab's Avatar
s1cab
Default What bhp is the limit using standard zetec valves ?
what power are the standard valves good for and what's their limit ?
2.0 silvertop zetec turbo
Old Mar 26, 2014 | 07:23 PM
Rsturbowayne's Avatar
Rsturbowayne
Originally Posted by s1cab
what power are the standard valves good for and what's their limit ? 2.0 silvertop zetec turbo
Mines between 190 & 200 bhp
Old Mar 26, 2014 | 07:30 PM
XRT_si's Avatar
XRT_si
The Devil Developments Fiesta was using standard sized valves at 592bhp, though I think they were PEC ones.
I know of a few Zetec turbos with well over 400bhp that used standard Ford valves.
Old Mar 26, 2014 | 07:36 PM
Rsturbowayne
Originally Posted by XRT_si
The Devil Developments Fiesta was using standard sized valves at 592bhp, though I think they were PEC ones. I know of a few Zetec turbos with well over 400bhp that used standard Ford valves.
Il have to see what needs up grading on mine , I wouldn't mind about 290 to 300 ish
Old Mar 26, 2014 | 07:47 PM
s1cab's Avatar
s1cab
That's good to hear i'm going for 420-450ish
Old Mar 26, 2014 | 07:53 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Lower Compression, turbo, valve springs, injectors, remap
Oh and you'd probably then want to upgrade the gearbox, brakes, bushes, engine and gearbox mounts too! lol
Old Mar 26, 2014 | 08:50 PM
Rsturbowayne
That all sounds abit expensive.:/
Old Mar 26, 2014 | 09:00 PM
crazycage's Avatar
crazycage
My 500+ zetec is on standard valves
Old Mar 26, 2014 | 09:02 PM
s1cab's Avatar
s1cab
That's good to know !
Old Mar 26, 2014 | 09:46 PM
Rsturbowayne
Originally Posted by Karlos G
Lower Compression, turbo, valve springs, injectors, remap Oh and you'd probably then want to upgrade the gearbox, brakes, bushes, engine and gearbox mounts too! lol
Now I'm just confused ?????????????
Old Mar 26, 2014 | 10:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The first few things are what you need to make 290-300bhp mate, then the rest will need changing to handle the extra power..... a RST with 300bhp will destroy a standard gearbox, the brakes will struggle to stop it, the engine and gearbox mounts will tear in half and the car will flex all over the place with standard rubber bushes.
Oh and you would need forged pistons and rods too.
Old Mar 27, 2014 | 07:43 AM
Rsturbowayne
The first few things are what you need to make 290-300bhp mate, then the rest will need changing to handle the extra power..... a RST with 300bhp will destroy a standard gearbox, the brakes will struggle to stop it, the engine and gearbox mounts will tear in half and the car will flex all over the place with standard rubber bushes. Oh and you would need forged pistons and rods too.
THE MASTER HAS SPOKEN" the apprentice is no longer confused! Lol
Old Mar 28, 2014 | 10:24 AM
Rsturbowayne
Would around the 250 mark be a lot easier and less expensive???
Old Mar 28, 2014 | 10:54 AM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
Build something cheap it won't last spend good money on on your bottom end ie pistons and rods!
And you always have scope for more power!!
You can have all the Gucci bits in the world like external wastegates and gt30 turbos but if you have a week engine it's just going to break
A good bottom end can be built for about Ł900 that will have the means to do 400hp
Old Mar 28, 2014 | 06:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
lol
You'd be pushing your engine at that power, easiest and cheapest option is to use an ST170 bottom end (good for 350bhp) with a Mondeo 2.0 Black Top head (fitted with the valve springs from the ST170 head).
I'll put a full list together when I get a chance mate as you asked, just mega busy getting cars out and sorting other bits with my holiday coming up next weekend.
Old Mar 28, 2014 | 06:44 PM
Rsturbowayne
lol You'd be pushing your engine at that power, easiest and cheapest option is to use an ST170 bottom end (good for 350bhp) with a Mondeo 2.0 Black Top head (fitted with the valve springs from the ST170 head). I'll put a full list together when I get a chance mate as you asked, just mega busy getting cars out and sorting other bits with my holiday coming up next weekend.
No hurry bud. Have a good holiday
fuzzy
21
Feb 15, 2016 10:26 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Chopshop85
Aug 17, 2015 06:38 PM
jay030787
Aug 17, 2015 06:16 PM
Churtz
15
Aug 13, 2015 06:40 PM
