is removing pedal box easy?
Old Mar 25, 2014 | 09:28 PM
col93saphcos's Avatar
col93saphcos
Default is removing pedal box easy?
Sure my pedal box is cracked/broken, is it a big job to take it out?what's involved?
its a 4x4 saph cos
CheeRs Colin
Old Mar 25, 2014 | 10:33 PM
lacey's Avatar
lacey
Pedal box out of a sierra is easy mate
The hardest bit is the blood rushing to your
Head while laying up side down doing it lol
Old Mar 26, 2014 | 11:35 AM
Cossy Mike's Avatar
Cossy Mike
Take the drivers seat out to make it a bit easier if your a big bloke
other than that it's 4 nyloc nuts and unhook the throttle and clutch cable and it drops off
Old Mar 26, 2014 | 11:48 AM
dojj's Avatar
dojj
Resident Wrestling Legend
it's very easy
there are 3 nuts that hold it in place plus a bolt hidden away up top somewhere
just use a long extension and make sure you have a torch
just be aware that the pedal box also holds the abs stuff on the other side of the bulkhead, so you only need to to the top right and both bottom nuts, the top left one "should" be just sitting there doing nothing but holding the abs in place
also it's easier to remove the clutch cable by pressing the pedal and then jamming a screw driver into the fork so that it's just as easy to put back in again afterwards
mine collapsed years ago and i spent money on a new clutch before i figured out it was the box
CLIVE
Oct 2, 2015 12:58 PM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
YODI
Aug 30, 2015 01:12 PM
Aug 29, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
