escos running lean?
Old Mar 25, 2014 | 09:06 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
Default escos running lean?
Hi guys my mate has just asked me to post as he's not a member. He has just done the head gasket on his car and fitted an inlet plenum spacer (think its 14mm) the car is now running lean on his afr gauge but was ok before the head gasket was changed. Is it possible the spacer has knocked the fuelling out this much? Its running standard cams with verniers but he has some standard cam pulleys to put on to rule the cam timing out as the heads been stripped and reassembled by an engine shop and he's unsure if the verniers have been moved. Ive told him to take it and have it set up properly instead of trying to guess but any suggestions welcome. Thanks nick.
Old Mar 28, 2014 | 05:39 PM
beaver rs 88
in the garage
Anyone? I no I posted in the wrong section but I dunno how to move it to the escort cosworth section.
Old Mar 28, 2014 | 08:17 PM
jsa's Avatar
jsa
Is it a ST car - if so look for air leaks after the AFM.
Old Mar 28, 2014 | 10:38 PM
beaver rs 88
in the garage
Sorry should have said its an escort cosworth
Old Mar 29, 2014 | 07:29 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I think jsa is referring to ST as being a small turbo escos as opposed to a BT for big turbo.
Old Mar 29, 2014 | 12:44 PM
Paul_RS's Avatar
Paul_RS
First mistake is trusting an incar AFR gauge. Take the car to a proper tuner with a proper gauge.
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
gcfcos
Sep 11, 2015 06:03 PM
Mickeystewart
Sep 9, 2015 04:04 PM
