4wd inlet what rail?
Old Mar 24, 2014 | 05:01 PM
cossie891's Avatar
cossie891
Default 4wd inlet what rail?
Will a 2wd rail and reg fit a 4x4 inlet manifold or will I need to use a 4x4 rail and reg?
Old Mar 24, 2014 | 05:19 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
I'll post some pics to secs
Old Mar 24, 2014 | 05:24 PM
DixieTheKid
Pick-up P100 Power!
Not unless you can tig weld ?
cossie891's Avatar
cossie891
right ok cool cheers mate
Old Mar 24, 2014 | 05:28 PM
cossie891's Avatar
cossie891
Dixie I have a 2wd man on my 3 door and wanted to fit a 4x4 inlet do you reckon its better with it is it just the elbow?
Old Mar 24, 2014 | 05:38 PM
Toe Knee's Avatar
Toe Knee
I did te same but didn't tig weld new brackets on just used a structural adhesive and not had any problems.
Will take a pic when I get a sec, it's what we use on the 12c's so good enough for a fuel rail
Old Mar 24, 2014 | 05:39 PM
cossie891's Avatar
cossie891
I have a 4x4 rail with FPR here so its not a problem
Is it worthwhile changing manifolds tho?
Old Mar 24, 2014 | 05:40 PM
DixieTheKid
Pick-up P100 Power!
4x4 flows better and more evenly. I have one for sale as it happens. not the rail or reg tho
Old Mar 24, 2014 | 05:41 PM
cossie891's Avatar
cossie891
Its ok a mate has one here lol I have a tb rail and reg already
Old Mar 24, 2014 | 05:44 PM
DixieTheKid
Pick-up P100 Power!
well worth doing
Old Mar 24, 2014 | 06:56 PM
cossie891's Avatar
cossie891
Ok cool what about the throttle body 4x4 or 2wd?
Old Mar 24, 2014 | 07:33 PM
DixieTheKid
Pick-up P100 Power!
Use either mate. They both fit
If you use a 4x4 don't for get to use a pf 01
Old Mar 24, 2014 | 07:36 PM
cossie891's Avatar
cossie891
Running L8 mate are both throttle bodies the same ie is one better
Old Mar 24, 2014 | 07:39 PM
DixieTheKid
Pick-up P100 Power!
Don't quote me on this but I think the idle screws are a different size
Old Mar 24, 2014 | 07:40 PM
cossie891's Avatar
cossie891
Ok but apart from that
will one be better than the other? I will prob just use my 2wd one and sell the 4x4 one
Old Mar 24, 2014 | 07:42 PM
DixieTheKid
Pick-up P100 Power!
No one will not preform better than the other if they are both std
Old Mar 24, 2014 | 07:44 PM
cossie891's Avatar
cossie891
Right ok cool thanks for the info pal
Nov 1, 2015 06:53 PM
155lee
Oct 27, 2015 04:55 AM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
