rs turbo dump valve
Hi after a bit of advice . i have a standard escort rs turbo. well apart from /31 actuator and stainlesss scorpion system. is there any advantage to fitting a dump valve ? i do have a turbosystems chipped ecu which i was going to fit at some point of the future. any help greatly appreciated Daz
Massive can of worms this one.
Many people are adament that the T3 is a pretty robust turbo and can manage without one even in the higher boost figures.
There is the argument that ford never fitted one so they dont need them, with the rebuttal being most people are running much more than standard boost.
I personally found the only difference running a DV is the lag between gear changes. Yes the DV releases pressure and allows the turbo to free wheel which would reduce lag, however the turbo then needs to repressurise the intake which has had all the air "dumped" out of it.
I have been running at just over 1 bar on a t3 for nearly 2 years with regular hard use. still its fine.as said I think a dv is only beneficial on high boosted t3's as there fairly tough so it shud aid turbo life. the noise also gets on my tits, they sound much better without. but its down to personal preference
When I had my Fiesta I did both and in the end opted for the DV,
My mate had issues with letting his turbo chatter as he was adament it killed 2 of them but the dump valve "saved" the 3rd one.
This was a T2 though and not T3
But here's my 'I ran x boost' story... No DV, 32psi .48/60 T3 used daily 3 years on still working fine, now on a Zetec Turbo.
Matt Baxter
Sep 16, 2015 08:30 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
rsstav
Aug 11, 2015 04:22 AM
