What next?
Old Mar 11, 2014 | 07:10 PM
BIL N KEL's Avatar
BIL N KEL
Default What next?
I'm at a point with my car where I don't know what to do next. My spec at the min is standard 4x4 head with bd14 inlet, 200 block proper long studded, cosworth racing forged pistons with valve cut outs, standard crank, grey injectors, t34.63
What do you think I should do next? I was thinking change the turbo for something else or headwork etc. where do you think my money would be best spent and on what? I would like it a little less laggy as I prefered how it drove with the .48 housing
Billy
Old Mar 11, 2014 | 07:55 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Head work, Nice flowing big valve head would be good money spent as a turbo is less effort to fit, you know one you have the head done you will have a good solid engine
Old Mar 11, 2014 | 07:58 PM
KSA-Cossie's Avatar
KSA-Cossie
Head work and a GT or Borg turbo
Old Mar 11, 2014 | 08:04 PM
Caddyshack's Avatar
Caddyshack
Borg turbo seems the way to go, I am doing this with modern ecu (vipec) , new loom coil on plugs and then add a close ratio box to keep it all on song.... I think head work will release more power but not sure on the low down side of things.....if you preferred the smaller turbo then the Borg is the first start as it will out spool and out power the smallest t34.
Old Mar 11, 2014 | 08:38 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Fit a GT3071 and some modern injectors
Old Mar 11, 2014 | 09:58 PM
BIL N KEL's Avatar
BIL N KEL
I've been looking at gt30's but didn't know which one as there was many different ones lol my t34 has been on there for 8yrs and I think it's getting a bit tired. What would I gain from a gt30 over a t34?
Old Mar 11, 2014 | 10:25 PM
matthewpickup's Avatar
matthewpickup
t34 .48 with a marm shaft ? like RSMATS 3 dr
Old Mar 12, 2014 | 05:13 AM
Staffi's Avatar
Staffi
T36 aren't bad
Old Mar 12, 2014 | 04:06 PM
BIL N KEL's Avatar
BIL N KEL
Originally Posted by Staffi
T36 aren't bad
What's one of them?
