Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Removing rear light cluster off a mk 1 focus!
Old Mar 8, 2014 | 06:51 AM
Breathren's Avatar
Breathren
Default Removing rear light cluster off a mk 1 focus!
I need to change my back brake light but can't for the life of me get the light cluster off. I don't want to be to forceful and brake it. Any tips please?
Old Mar 8, 2014 | 07:10 AM
STeve's Avatar
Super Moderator
hand twist nut inside the boot and a screw on outside and pull away
Old Mar 8, 2014 | 09:15 AM
cabriolet's Avatar
cabriolet
inside thingy seems to take forever keep twiddling .take out screw visible from outside gently lift out change blub
Old Mar 8, 2014 | 09:17 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the nuts are normally plastic and there should only be 2 of them
otherwise you may find that they are 10 or 11mm nuts on the back
the light units should then just slide out backwards
it was much easier when you could change the bulbs by simply removing the cover from inside and swapping bulbs on the rear
Old Mar 8, 2014 | 12:03 PM
robch1983's Avatar
robch1983
as above there is a hand twist nut thingy inside the boot towards the bottom of the light housing then a screw about halfway up the light just to the side of the light then the light is held in place at the top by a peg that pushes into a plastic clip/holder mine was a right bugger to remove thought i was going to break it if you wiggle the light side to side it eventually comes free
Old Mar 8, 2014 | 07:52 PM
Breathren's Avatar
Breathren
Thanks everyone,I shall attempt this feat in the morning!
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
sridgett
15
Aug 3, 2015 07:26 PM
