Fiesta ST This forum is for discussion of all things pertaining to the Ford Fiesta ST Range of cars.
Higher mileage Fiesta ST as a runabout?
Old Feb 27, 2014 | 07:44 PM
cfoster's Avatar
cfoster
Default Higher mileage Fiesta ST as a runabout?
Looking at buying myself a runabout and quite fancy a Fiesta ST (around a 55/56 plate), seen them around the £2800/£3500 so on budget. Would buying one with 100k miles put you off, what sort of things are likely to fail on the engine at this mileage apart from clutch etc (if that hasnt already been done). There is one for sale locally to me for £3 on 101k but just had service at Ford 2000 miles ago?
Old Feb 27, 2014 | 08:13 PM
zippyobrien's Avatar
zippyobrien
I sold one 6 months ago. 55 plate. 42k on the clock. Was mint !! For 3100.
Shop about you can get low mialage ones. Although they seem to have got a little more expensive recently ???
Old Feb 27, 2014 | 08:14 PM
zippyobrien
And piston rings and valve guides / springs wear. Gear boxes loose the synchromesh on second and third. So the box will pop out on over run. Also diff bearing wear resulting in exploded gear box.
Apart from that. Really reliable.
Old Feb 27, 2014 | 08:23 PM
maxest's Avatar
maxest
Buy a Clio 182 instead get more for your money
Old Feb 27, 2014 | 08:26 PM
cossie330's Avatar
cossie330
Mine has 76000 on the clock, bought it on 66000 seams a really solid little car apart from the gearbox pops out of second on overrun sometimes but they are smart cars for the money. I paid £3300 for mine
Old Feb 27, 2014 | 08:31 PM
zippyobrien
I currently have a 182 as a Dailey. And yes there a bit quicker etc and a bit cheaper.
I'm thinking about selling it for another fiesta st. There just sooooooo much nicer to live with.
Pop it on 16s , 185 kit and there a great all rounder. A lot better on fuel to
Old Feb 27, 2014 | 08:38 PM
Just buy one. They should be ok with over 100k miles on.
Old Feb 27, 2014 | 08:45 PM
matts1's Avatar
matts1
they seem to be a pretty tough little motor the ST.
Old Feb 27, 2014 | 09:00 PM
cfoster's Avatar
cfoster
My ex missus had one and it was a hoot to drive, ok not the quickest thing on the road but was silly cheap to run and was great fun!
As said above some 16" esc cossie wheels, i'll probably end up wrapping it knowing my track record, may even convert it to a van on the outside (wrap rear quarters!)....
Not a fan of 182's i'm afraid....
Old Feb 28, 2014 | 12:05 PM
philg12's Avatar
philg12
mine is a 2005 with 70000 miles on it. had it since 2006 with 6000 miles on it
problems ive had are,
blown engine, (would be classed as my fault cause i used to thrash it around when i was younger)
new alternator,
lowering springs snapped on the front and rear,
ive have heard a lot of stories about blown gearbox's but mine has never had a problem?
and i take it on track and generally abuse it at the weekends!
Old Feb 28, 2014 | 02:44 PM
liam-rst's Avatar
liam-rst
shit happens
Not an st but my mums 55reg 1.4 fiesta has done 156k and the thing dont miss a beat, to drive is lovely too and still all nice and tight
Old Mar 9, 2014 | 07:57 PM
Black2's Avatar
Black2
They are tuff cars and v reliable. Its like any car; if idiots have owned them and thrashed them every time they are driven then there are going to be issues.
Mines just ticked 96k and has been nothing but ultra reliable, the original clutch is still going strong. Its been well looked after, I bought it new and it has not been driven like a total tool. No issues with gears popping out or crunching or anything like that. All ive had to do is maintain it and replace wear and tear items.
However im sure there are cars with far less miles than mine that are experiencing issues due to poor treatment.
If you get a good one they are quite cheap to run, plus no cambelt to worry about.
Gareth.
Old Mar 10, 2014 | 09:38 AM
Straight_4_N/a's Avatar
Straight_4_N/a
Seems abit much for such an old car with 100k.
iirc the going price for them around that year and milage was £2,500
Old Mar 10, 2014 | 09:43 AM
Straight_4_N/a
Quick look on flebay and you can get them for £2,600 on 90k! Which you could knock a few hundred off lol.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
