anyone else had puddles in their cars?
Old Feb 16, 2014 | 11:16 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Default anyone else had puddles in their cars?
was going to post this in the mondeo section mods BUT i'm sure that it is something that has affected more than just mk3 mondeo estate owners so i'm posting it here so that everyone can share their views
got into the car today after several weeks of inactivity and the passenger rear footwell is full of water, i mean FULL of water, above even the carpet level
ok, this is another job for me to solve but the fiesta also had a bootful of water where it was leaking form a seal for the wiper
is it just me or do even "modern" cars have the inherent ability to not be able to stay water tight in some wet weather?
i mean, surely you'd expect your car to survive the occasional bit of rain?
anyone else suffered wet cars in the rain?
Old Feb 16, 2014 | 11:21 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
My Mk2 mondeo is fine and stays outside all the time.
The Sharan does have a wet drivers side front carpet but not with water laying on top.
Both sierra's are fine, but then they do live in the garage lol
Steve
Old Feb 16, 2014 | 12:27 PM
Cossie.jack's Avatar
Cossie.jack
The other week I was cleaning a bmw 118d with the jet wash and that leaked through one of the back windows slightly. At first I thought It was my fault by holding the jet wash too close but the owner said it happens in strong rain too!
Old Feb 16, 2014 | 12:44 PM
RichieST's Avatar
RichieST
My mk4 Mondeo pisses water in the boot and fills up the spare wheel well. It's supposed to be the seal around the fuel filler neck that causes it, but I've not yet investigated.
Old Feb 16, 2014 | 12:55 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
All the time, bitches be soaking.
Old Feb 16, 2014 | 12:59 PM
BigErn's Avatar
BigErn
My Leon gets wet foot wells, the Discovery leaks in somewhere behind the dash and the water runs in through the speaker on the c post and I noticed yesterday in the rain the Cossie has a water leak too..... Id be drier using my bike
Old Feb 16, 2014 | 02:05 PM
stboy's Avatar
stboy
Wet footwells on mk3 mondeo is more than likely going to be the door membrane seals. I've done loads of these in the past. once its wet it wont re stick so any water going through the door pours into the footwells. Carpets have foam padding underneath which can take a while to dry out. Worth checking first. Just remove the door trim and check. Hope this helps.
Old Feb 16, 2014 | 02:10 PM
Our old mk3 mondeo turned out to be up above the glove box and fuse box ,on the inside, water getting in through the body sealer at the a pillar ,re sealed with tiger seal ,problem cured ,water was coming in as we was driving along ,actually took out the carpet for a few weeks to find the problem ,could see a trail of water coming down the foot well ,had done all the other usual cures before we found this one
Old Feb 16, 2014 | 03:08 PM
Yoy should get a 1 series bmw cause my sisters boy friends bmw was in his works car park and all the cars got flooded inside them apart from his bmw apparently lol.
Old Feb 16, 2014 | 03:16 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I just got a pajero swb to smoke about in and it leaks like fuck lol
My bro works for autoglass so we are doing the screen tomorrow as some one has siliconed the bottom corners so fingers crossed
Old Oct 14, 2014 | 02:41 PM
superdome's Avatar
superdome
I have a 1990 XR2i...keep getting water in drivers foot well in rain...wheres it coming from..?
Old Oct 14, 2014 | 04:11 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Probably through the rot in the floor pan
Old Oct 14, 2014 | 05:26 PM
turbolee's Avatar
turbolee
my brother was getting water in footwell in picasso there was a plastic pipe under wheel arch that was blocked we cleared it all well now
Old Oct 14, 2014 | 06:39 PM
bigdel's Avatar
bigdel
My lad's Corsa was full of water last winter. It had been standing for a few weeks, and it had got so damp, there was mould growing on the seats
Driver footwell was full of water. Now sorted, needed a Ł2 gasket behind the brake servo..
Old Oct 15, 2014 | 08:09 PM
Ridgey's Avatar
Ridgey
Our mk3 leaked through the door membrane, then it drips onto the sill seal from the bottom of the door and runs inside the car.
Bit of fiddling and extra silicone sealant on the inside of the waterproof membrane fixed it.
Old Oct 17, 2014 | 03:43 PM
Marcyg's Avatar
Marcyg
They're well known for that little party trick
steerfromdarear
28
Jan 29, 2016 06:14 PM
Shows & Track Days
Aug 26, 2015 05:11 AM
Bailes1992
Aug 16, 2015 07:14 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
