909 Top mounts fitting problems
Old Feb 14, 2014 | 04:08 PM
Brocker's Avatar
Brocker
Default 909 Top mounts fitting problems
I get a set of 909 top mounts from the bay, now i have problem..
The top peace will not fit into the top rubber, i tried with oil and all my body weight, but they
will not get in without destroy the rubbers..
is there any trick or something to fit them??
Attached Thumbnails 909 Top mounts fitting problems-anhang-1-3-.jpg   909 Top mounts fitting problems-anhang-2.jpg   909 Top mounts fitting problems-anhang-3.jpg   909 Top mounts fitting problems-anhang-4.jpg
Old Feb 14, 2014 | 10:02 PM
IainRS1700T's Avatar
IainRS1700T
Mate, I might be wrong here, but I'm not sure you can fit those with a regular rubber bush from a road car.
Mine are similar but are bolted to an eccentric top mount that goes on the underside of the turret, and the part on the top side (similar to the one you've pictured) carries a bearing that the threaded rod of the damper fits through, and is secured by a top nut. There's no rubber bushes involved.
Hope you find a solution.
Iain
Old Feb 14, 2014 | 11:11 PM
Brocker's Avatar
Brocker
They must fit into the rubbers in my opinion, here are the link from the pay and
of a thread from here with similar ones:
http://www.ebay.de/itm/331101695857?...84.m1439.l2649
https://passionford.com/forum/genera...op-mounts.html
Old Feb 15, 2014 | 10:16 AM
Paul_RS's Avatar
Paul_RS
Use soap.
They are designed to be used with the original bushes IanRS1700T has different mounts. Also, fit the mounts to the rubber BEFORE you fit the shocks. You need a tool to tighten the top nut ass well.
These are mine fitted
Old Feb 15, 2014 | 10:41 AM
Brocker's Avatar
Brocker
The lower part fits in the rubber, but the top part dont reach the thread, i didn`t get it deep enough into the rubber bush as i show in the picture..
Old Feb 15, 2014 | 04:38 PM
Brocker's Avatar
Brocker
I think there is something wrong with my top mounts, i cant mount them, i allready destroyes a bush at trying to mount them..
If i messure the bush hole i have 52mm and the top peace of top mount have 58mm..
Attached Thumbnails 909 Top mounts fitting problems-anhang-2-1-.jpg   909 Top mounts fitting problems-anhang-5.jpg   909 Top mounts fitting problems-anhang-1-4-.jpg
Old Feb 16, 2014 | 11:50 AM
Paul_RS's Avatar
Paul_RS
Are the bushes genuine ford?
Old Feb 16, 2014 | 12:28 PM
Brocker's Avatar
Brocker
Yes they are
Old Feb 16, 2014 | 03:27 PM
Paul_RS's Avatar
Paul_RS
Strange, my top mount was a tight fit, bit it didn't rip anything.
Old Feb 16, 2014 | 04:22 PM
Brocker's Avatar
Brocker
There are my bushes
Here i lift the car from the bottom at the lower part of the top mount..
still not enough to bold the upper part on
I think there are at least 5-10mm space between the treads
Attached Thumbnails 909 Top mounts fitting problems-anhang-3-2-.jpg   909 Top mounts fitting problems-anhang-5-1-.jpg   909 Top mounts fitting problems-anhang-6.jpg   909 Top mounts fitting problems-anhang-10.jpg
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
matman
Sep 9, 2015 05:45 PM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
sierra cossie
Aug 7, 2015 12:17 AM
