Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
transit connect glow plug light
Old Feb 14, 2014 | 09:31 AM
28martin28's Avatar
28martin28
Default transit connect glow plug light
i recently bought a 2004 connect 1.8tdci
after a week of pottering around all being fine, i took it on a job witch included a motor way stretch.
after around 15 miles the glow plug light started to flash and the engine cut out. after a couple of minutes on the hard shoulder i tried to start the van and all was well for another few miles. after eventually getting to the job i realise that, The van only does it when the engine is at running temperature and when you hit a slighty uphill. I had the van plugged in at my local garage and it came back as a fuel pressure sensor. Can anyone please shed some light on this problem as i have had a number of suggestions but none that are certain to cure it. I have listed the suggestions below from the garage it was plugged in.
fuel rack
fuel pump
fuel filter
one or all of the injectors
I am in need of some direction as money is tight at the min and dont want to spend the money on the wrong thing
thanks
Old Feb 14, 2014 | 06:04 PM
GVK.'s Avatar
GVK.
Really need to know the exact code P**** to advise.
Other than that it will require fuel injector leak off tests, and fuel pressure tests on live-data to determine the fault.
Can't just go guessing at stuff and throwing expensive parts at it.
First cheapest thing I would do is change the fuel filter though.
Been known to cure many faults on TDCIs.
Old Feb 17, 2014 | 11:04 AM
28martin28's Avatar
28martin28
Hi thanks for your reply, I have taken it back to the garage and the faultr code is po251.
injector pump fuel metering control A malfunction
Old Feb 17, 2014 | 05:33 PM
GVK.'s Avatar
GVK.
That usually means that the pump can not control the fuel pressure, and mostly is due to injector(s) leaking off excess amounts, as above, needs fuel pressure tests and fuel leak off tests on the injectors. Possibly the inlet metering valve on the pump.
If you do a search on this forum for 'p0251' you'll find a lot of info about it.
Old Mar 8, 2015 | 06:31 PM
bigsi234's Avatar
bigsi234
I have a 2004 connect wont start I have got these fault codes
p0409 and p2288 need help cant work without it lol
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
