Steering column issue
Simply had the column in the car and bolted up fine, took it out as i needed to sort something on the pedal box and now refitting the column it appears to have lost some of its length that pokes through the bulkhead - my heads battered and its been in and out about 6 times and nothing seems to have helped.
Anyone ever had this?
This has pickled my mind, i marked the shaft the other day before i removed so everything went back the same - replaced yesterday fine and matched the marks - removed today and went to replace and the mark is no where close - only 26mm of the shaft exposed in the engine bay side
it moves up and down a bit when you remove it if you've yanked it
it's not obvious but some parts of the column go inside other parts
also, make sure that the corrugated section at the top is still the correct shape and not had all the metal bits flattened down
it's a black collar that goes around the top of the column but sits below the bit the steering lock sits in
SMILER258
Sep 28, 2015 09:04 AM
