Poly V belt
Feb 8, 2014 | 03:08 PM
Poly V belt
Im after a shorter Poly v belt im not sure on measurements yet.Whats the best way to get the perfect measurement to ensure I get the right belt.
Feb 8, 2014 | 03:13 PM
run a piece of string around all of the pulleys and tensioner so both ends meet, then just measure the length of the string and get a poly vee belt in that length mate.
Feb 8, 2014 | 03:18 PM
Quote:
Originally Posted by
pcbp97
Sounds good to me.Can you get a shorter belt ie 500mm?
Feb 8, 2014 | 03:33 PM
If tou going tp run the alternator at the front why dont you biy a non ac puma belt I just got ome I can measuere it for ya
Feb 8, 2014 | 03:41 PM
bagginsRSturbo
Hi Ryan im only using the crank pully alternator pully and the water pump pully.Wouldnt your belt be to long?
Feb 8, 2014 | 03:59 PM
When I supercharged mine and had to get a new belt, I ran some string round and measured it, then done the same thing again but slackened the tensioner fully.... Then got a belt in the middle of the two measurements, so the tensioner was bang in the middle of its range of movement.
Matt
Feb 8, 2014 | 04:00 PM
Mk4 Rick
I would'nt know just having a guess tbh but il measure it and see it loads smaller then the one I had on before thou
Feb 8, 2014 | 04:06 PM
I no its gonna be short my last belt was a 1050mm im think this could be 600/700mm ive not seen any on ebay in that size lol
Feb 8, 2014 | 06:02 PM
Mk4 Rick
Put old belt on, cut it to size then measure.
Then buy new belt.
Feb 8, 2014 | 06:13 PM
stevieturbo
Then buy new belt.
I will give it a wirl tomorrow
Feb 9, 2014 | 03:12 PM
Im after a 840mm belt 4 ribbed not 6 ribbed.Can you get an 840mm belt?
Feb 9, 2014 | 03:20 PM
Feb 9, 2014 | 03:38 PM
That will do the job , get it ordered lol
Feb 9, 2014 | 03:43 PM
bagginsRSturbo
I went for an 830mm belt in the I had a bit extra in length.I don't have a lot of movement on the alternator.
Feb 9, 2014 | 04:06 PM
Yeah should be fine, how the rest of the car voming along
Feb 9, 2014 | 04:37 PM
bagginsRSturbo
Yeah its going well to be honest drives well enough.
Feb 9, 2014 | 04:39 PM
There are literally thousands of belt sizes, there's always something that will fit.
mk1turboestate
Dec 2, 2015 08:31 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
pabloXR
Sep 21, 2015 12:42 PM
