Problem with cone links and rose joints.
Wye Valley Hardcore
Ones anyone know of any other suppliers of cone links? This is the problem have, I'm making up rose jointed parallel and trailing arms with 5/8 joints but no cone links I can find will fit them. I have both types of Rally Design link shown below, compression links and tension links, but neither will fit a 5/8 joint. They must be available as I've seen them used before.
I can get around this by mounting them to the sides with a spacer tube in the middle (using the joints ideally on the left hand side as they are 1/3 of the price!) as I have seen others do, but it seems like a bit of a bodge when the proper joints must be out there somewhere. Besides, the tension strut links are £80 a pair which is a lot of money for something which doesn't fit 100%
The should fit like this
Anyone have any suggestions?
Wye Valley Hardcore
Who advices that, out of interest?
If that we're the case I guess you could use the cone link in the hub with a solid mount connected, like the end of a compression strut.
Ive checked mine and they are at 15mm. Why are you putting a bearing at the hub? Just fit one in board to the chassis and a fixed to the cone, you still get the same up/down radius.
That rod is for compliance control so doesnt need to turn.
Wye Valley Hardcore
Wye Valley Hardcore
run it this way ,add a piece of metal to fill the middle and weld up
http://img.photobucket.com/albums/v2...ps94c005dc.jpg
add the metal to the middle and weld round job sorted an run rose joint to side
http://img.photobucket.com/albums/v2...ps95941381.jpg
