RS500 Front lower splitter part numbers req
Old Feb 4, 2014 | 11:02 PM
nick8saff's Avatar
nick8saff
Default RS500 Front lower splitter part numbers req
As above need the part numbers if anyone can help.
Thanks
Old Feb 5, 2014 | 05:11 PM
Sonic Boom's Avatar
Sonic Boom
Paul @ NYRS will beable to help no doubt
Rich
Old Feb 6, 2014 | 02:17 PM
PAUL S's Avatar
PAUL S
here you go
9092733 Air splitter support front LH – black
9092732 Air splitter support front RH – black
Few more 500 numbers as well if anyone needs them
9092625 Heatshield – turbo /abs pump
9092627 Heatshield – hood top
9092386 Hose – amal valve – w/gate
9092635 Hose – valve to air/cleaner
9092425 Hose – turbo charger outlet to intercooler
9092426 Hose – intercooler to throttle hsg
9092427 Hose – air cleaner to turbo
9093096 Hose – water turbo cl
9092972 Kit aperture grille assy. – RH
9092971 Kit aperture grille assy. - LH
9092679 Decal – body side wing front – LH
9092680 Decal – body side wing front - RH
9092681 Decal – body stripe (6 metres per car req`d 1) 1metre
9092793 Decal – RS500 – rear
9092723 Bumper front airdam – moonstone
9092722 Bumper front airdam – black
9092724 Bumper front airdam – white
9092692 Protection sheet – rr spoiler – RH
9092693 Protection sheet – rr spoiler - LH
9092735 Spoiler rear lower
9092737 Rear aerofoil – upper – black
9092721 Rear aerofoil – upper – white
9092720 Rear aerofoil – upper – moonstone
9092786 Exhaust downpipe turbo to bulkhead
9093013 Thermostat
9093022 Plenum – intake elbow
9093025 Plenum – cover
9092924 Turbo charger
9093037 Oil pump assy
9093039 Water pump assy volume prod
9093095 Turbo damper rework kit
9093086 Damper assy turbocharger
1638293 Door mouldings
1638294 Door mouldings
1638295 Door mouldings
1638296 Door mouldings
1638297 Door mouldings
1638298 Door mouldings
9092903 Convoluted tube – hose protection 120mm
9092902 Convoluted tube – hose protection 100mm
9093286 Brkt. Inner pivot ext. hsg rear susp LH
9093289 Brkt inner pivot ext. hst rear susp RH
9092605 Seal – intercooler to radiator upper
9092606 Seal – intercooler to radiator lower
9092456 Bracket – intercooler to rad to body LH
9092457 Bracket – intercooler to rad to body RH
9092432 Hose – header tank
9092427 Shield – radiator
9092423 Hose radiator – lower
9092655 Cover plate bumper reinft
9092424 Hose – air bypass valve
9092471 Pipe – air bypass valve
9092678 Intercooler assy
9092390 Air cleaner lid
9092625 Tube – air cleaner intake
9092454 Plate alt. mtg.
9092458 Arm – alt belt adjust
9092690 Bracket – map sensor mtg.
9092698 Ecu – module
9092671 Bracket – horn mtg.
9092672 Bracket – horn mtg.
9092684 Nut – m5x30x10mm af
9092708 Spacer rad mtg
9092674 Edge clip
9091522 Hose tie 200mm x 2.5mm
9092689 Hose tie 390mm x 4.6mm
9092702 Hose clamp 60 – 80
9092650 Engine assy hot tested
9092704 Hose clamp 70 – 90
9092695 Hose clamp 25 – 40
1650573 Hose clamp 30 – 45
9092718 RS500 original cylinder block
9093002 Idle speed regulator retainer
9093003 Idle speed regulator
9093004 Throttle position switch
1640040 Sender – water temperature
9093012 Water outlet & thermostat housing
9093014 Bracket – throttle cable mounting
9093018 Throttle body assy.
9093021 Gasket – throttle body / plenum
9093026 Gasket – lower plenum
9093027 Inlet manifold
9093028 Fuel rail assy – upper
9093030 Regulator – fuel pressure
9093033 Gasket- inlet manifold
9092925 Oil pump inlet / cooling rail assy.
9093040 Spacer – thermostat
9093041 Gasket – thermostat elbow
9093042 Spacer turbo oil pipe / cam cover
9093043 Pipe – turbo oil feed
9093044 Elbow – thermostat housing
9093045 Fuel rail assy – lower
9093047 Fuel transfer hose
9093048 Hose – lower fuel rail / relief valve
9093049 Moulded pipe – throttle body / plenum elbow
9093050 Hose – water pump / thermostat housing
9093052 Gasket – thermostat housing
9093053 Pipe – heater to water pump
9093054 Hose – heater to water pump
9093056 Hose – water pump stub.
9093083 Exhaust valve
9093093 Pipe – water o/l turbo
9093094 Hose rad overflow
9093095 Clip – water pipe
1514328 Spacer
9093065 Inlet pipe – water cooled housing
9093071 Gasket – oil pump body / pickup flange
9093072 Plug – fuel press reg.
9093074 Piston say c/w fins, circlip, rings (rs500 block only)
9093073 Sheath – heater return pipe
9093077 Rubber hose valve / plenum
9093079 Flexi pipe – fuel rail pressure
9093081 Service cylinder head assy
9093000 Misc hardware rebuild kit
M51870025 Spirol pin 5mm x 12mm mbk – inlet manifold to head
1473188 Screw m5 x 10 lg hex head grade 8.8 airbleed – water out
1613296 Bolt m6 x 55 hex head grade plated – turbo clamping damper
6163723 Copper washer m6 12.5 x 6.4 x.8 – airbleed water outlet hsg.
1503011 Bolt m6 x 80 hex head grade 8.8 plated int. elbow to plenum
MS1870035 Spirol pin 2.5mm x 8mm mbk idle speed valve to intake elbow
M51105025 Screw m5 x14 cheese head slotted plated – idle valve to intake elbow
206416 Spring washer m5 single coil idle speed valve to intake elbow
E602214572 Screw m10 x 55 hex. Head grade – water pump to head
H88H9E499AA 90 degree male elbow 3/8 nptf ybd – thermostat housing
M518055245 Screw m6 x 25 s.c.h. grade 12.9 e-coated – tur oil pipe clip to cam cover
9091752 Screw m8 x 25 s.c.h. e-coated therm hsg to cyl head
M51863855 Red cap – transportation – throttle housing
M51863855 Red cap – transportation – turbo
M51601615 O ring – throttle switch to throttle body
M51601615 O ring – idle speed valve to intake elbow
M51601625 O ring - idle speed valve to intake elbow
M51830545 Washer square throttle switch mounting
M51106015 Screw and integral washer throttle switch mounting
M51850155100 Jubilee clip – size 2a 32mm – 50mm
1519545 Insulator – intercooler to top chassis mounting
6170132 Fuel clip
1579614 Rivet 4.0 x 8.9 rear aerofoil to tailgate
1467848 Washer flat air splitter to bumper
1571868 Nut nyloc air slitter to bumper
6112228 Nut – m10 engine mount to insulator
1494742 Screw m6 x 16 intercooler to radiator
1579565 Nut spring intercooler to radiator
1475363 Bolt m8 x 40 hex head intercooler to chassis
1471553 Washer flat intercooler to chassis
1640474 Clamp – 8-10 emission pipe
1629583 Nut m12 rear suspension inner pivot to wishbone
1955305 Nut m10 turbo to muffler inlet pipe
6159481 Bolt – m10 x 50 exhaust pipe to convertors
1509658 Strap secondary engine loom
Old Feb 6, 2014 | 02:53 PM
R5FORD's Avatar
R5FORD
Awesome info paul
Old Feb 6, 2014 | 04:14 PM
PAUL S's Avatar
PAUL S
I would love to claim I put it together Aaron but I found it on the net years ago and saved it on my PC
Old Feb 6, 2014 | 04:26 PM
Jay,'s Avatar
Jay,
Sponsor
But most parts of those days are 909 RARE AS ROCKING HORSE SHIT
Old Feb 6, 2014 | 05:24 PM
opposite lock's Avatar
opposite lock
Jesus thats mental.
Old Feb 8, 2014 | 04:17 PM
nick8saff's Avatar
nick8saff
Thats great, thank you very much it was very helpful
C2 MAK
Aug 20, 2015 09:46 PM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
Botts
Aug 13, 2015 04:16 PM
TIL13R
11
Aug 13, 2015 02:28 PM
