2wd diff cooler options?
Has anyone fitted a diff cooler to there cossie? Driving back from a show on sunday in 40+ degrees my diff decides to vent out a fair bit of oil been told by quaife its due to the heat so need to look at diff cooling options
They had a pump but you needed to trigger the diff oil temp AND speed switch to activate the pump. Temp was around 130 deg C and speed over about 75mph on the S14.
S13 was same temp but any speed over about 6mph to trigger pump
They're on my computer at home, I'll dig them out
Big over kill if you ask me but the cooler alone should be enough
