mondeo diesel leakoff test
Old Feb 3, 2014 | 06:15 PM
garfield65's Avatar
garfield65
Default mondeo diesel leakoff test
I am going to do a leak off test on my mondeo. its a 53plate 115ps. is it best to do it on tickover or disconnect the electrics to the injectors.
Old Feb 3, 2014 | 06:16 PM
saph4be's Avatar
saph4be
You do it with the engine running bud
Old Feb 3, 2014 | 07:56 PM
garfield65's Avatar
garfield65
any idea how long you leave it running for. and how much diesel roughly will come out. thanks
Old Feb 3, 2014 | 08:32 PM
JOHNDQ's Avatar
JOHNDQ
the correct way is to disconnect injectors and pressure regular, crank engine you should have over 1000bar in rail and less than 10cm in leak off tubes
Old Feb 4, 2014 | 12:02 AM
garfield65's Avatar
garfield65
Thank you. As soon as my manflu gone I will check. Thanks
Old Feb 4, 2014 | 06:21 AM
DangerousBryan's Avatar
DangerousBryan
If you then connect all the electrics back up. Run it for 1 minute and the diesel should just of about reached the bottles. Basiclly your looking to make sure there all the same. Any that are significantly high are dead.
Old Feb 19, 2014 | 07:24 AM
garfield65's Avatar
garfield65
Thank you I will try that this morning.
mark94
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
