2wd Saff for Sale (NOW SOLD)
Hi All
I’m selling my 2wd Saff, I’ve not owned it for long approx 3 months but a baby on the way force’s the sale.
The car has lots of receipts and some of its mots, it reads 84k on the clock and I believe the mileage to be genuine as the underneath is clean (seals ect no rust). The mots and previous HPI checks from 2006 Talley up with the mileage it’s covered less than 10k, the bloke who owned it between 2006- 2013 he never drove it, there are also a few sorns for the vehicle from the previous owner before the person I bought it off.
Good Points
2 keys & Toad Alarm with 2 fobs Cat1 alarm & Tracker but not active
ECU cover with RS Logo (There fetching £90-100 on ebay)
Alpine head unit (but no speakers are wired in)
Polly bushed all round
Power coated rear beam and front roll bar
Gaz Coil overs
4x4 bonnet
Leather good condition
Wheels and tyres in good condition
Dash is good
Scorpion Exhaust
Greys
3 bar map
-31
T4, but don’t feel laggy so I reckon the front compressor is a T4 and the Exhaust compressor is smaller.
Alloy Rad and RS 500 intercooler (Fans all working)
Silicon hoses all round.
Baileys Header tank & Swill pot
Baileys oil breather.
New battery.
The previous owner put in new plugs, oils, belts, rotor arm and dizzy cap In September 2013. He also installed a recon T5 box with a new clutch, these has covered less than 500miles and re-built rear diff. The person before me got the car at fair price which cost him, due to the car sitting around for years under cover.
There’s a receipt for a top end rebuilt in 2005 from Matt Lewis motorsport, cross referencing this receipt with the mot that would have been done appox 10000 miles ago inculding a group a head gasket. The engine starts-up on the button with no smoke or rattles at all. The car was RR at 358bhp but couldn’t tell you when that was no date on the RR graph.
Bad Points
The rear arches are showing slight signs of rust but not bad at all see the pictures.
The front door cards have seen better day’s driver side is the worsted
The rear boot lock has ceased from under use.
Couple of small dents could be removed with dent less removal.
The driver’s side rear door has bad rust, this was the location where the car cover split but I have a replacement door to go with the sale (Same colour)
Fuel tank had a slight leak it was fixed but I was going to change it as the fix wasn’t the best.
Distributor cap needs a clip ones missing
The front passenger’s door shows as being open on the front monitor.
The general body work is good £200-500 depending how fussy you are would make this car mint.
As for all the other bits, it’s a little time and a little bit of money.
The car is HPI cleared just had number plate’s changes, Mot until 13th of September 2014 Tax till end of Feb 2013.
I will be conducting all the test drives too many people out there just want to waste people’s time
The car is only advertised here at the moment but will go on Ebay if I have no luck.
As for the Price I want £5200 no offers that will include the new door
Cheers for reading
Simon
Sydneyvon@hotmail.com
07904921212 text is better as I work a lot and I’ll call you back.
Good Points
Gaz Coil overs
4x4 bonnet
Dash is good
Scorpion Exhaust
Greys
3 bar map
-31
New battery.
Bad Points
Cheers for reading
Simon
FlashRS
13
Aug 31, 2015 06:02 PM
