Ford Puma Discuss the Ford Puma here!
Few MOT adviseries
Old Jan 28, 2014 | 03:35 PM
Fordmad!'s Avatar
Fordmad!
Default Few MOT adviseries
Advisory's are both rear subframe bushes.
Im guessing they are going to be a pain and not cheap labour wise?
What sort of £££ am I looking at?
Advisory on abit of welding and a bearing but that isn't too bad!
Old Jan 28, 2014 | 03:58 PM
bagginsRSturbo's Avatar
bagginsRSturbo
Piece of piss mate, your better of dropping the beam as it makes life alot easier
Old Jan 28, 2014 | 04:53 PM
Fordmad!'s Avatar
Fordmad!
That's good to hear, had a feeling it was going to be a pain!
Old Jan 28, 2014 | 05:02 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Easy job if you drop the beam off. Only two bushes on the rears anyway!
Old Jan 30, 2014 | 08:56 PM
I just dropped the beam down then attacked the rubber with a drill to get the inside of the bush out. Then I hot a hacksaw and cut the outer part of the bush then chesiled it out. I checked my pooma over cause its due its mot next week and I noticed there is plenty of movement on the bushes I fitted. This is properly what causes the rear tyres to wear off.
Old Feb 1, 2014 | 10:45 AM
STeve's Avatar
Super Moderator
such a cheap fix but a pain in the ass to do
Old Feb 5, 2014 | 02:20 PM
I checked my rear bushes cause my car has just passed its mot. They arnt worn but if you lever them with a bar they dont half move. Poly bushes would get rid of the play and are easier to refit.
Old Feb 5, 2014 | 03:36 PM
Fordmad!'s Avatar
Fordmad!
Mine knock like hell, he said he should of failed them really but I said id get them done asap!
How much would someone charge me on average to do them?
Old Feb 5, 2014 | 04:14 PM
coolblue's Avatar
coolblue
Drilled mine out with a drill and hss holesaw without the pilot drill fitted , then got the metal shell out "gentley" with a junior hacksaw and finally a big screwdriver .not to bad a job.
Old Feb 5, 2014 | 09:05 PM
STeve's Avatar
Super Moderator
I would say an hours labour plus parts and defo get poly ones not OE
Old Feb 9, 2014 | 02:19 PM
I set to mine with a drill too. I wish I fitted poly bushes now.
Old Feb 9, 2014 | 05:46 PM
coolblue's Avatar
coolblue
Poly,s best, going to to do ARB and front lowers before this years trackdays
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Nick 172 Sport
Sep 28, 2015 07:21 PM
