Motec ADL (Advanced Data Logger) Backlit Dash
Motec ADL (Advanced Data Logger) Backlit Dash.
Comes complete with upgrades to:
8MB logging
50 Inputs/Outputs
Pro Logging
I have the mating Autosport connector and will supply new Deutsch pins for it. I will also include a brand new backlight inverter module to ensure the backlight functions perfectly.
This dash has come from a 2008 British SuperBike spec bike that was never competed and is in very good condition thanks to the clear plastic cover it has lived under.
It can be used to display data from a variety of ECU's via CAN/Serial datastream or used as a standalone device with external sensors.
The current ADL with options upgrades is priced around £5000+ VAT, I'm asking £1500 for a quick sale on this.
The dash in it's protective plastic cover - can be removed
Serial number should you wish to verify with Motec Europe
For those unfamiliar how it can look with the backlight on:
An example of how it can look installed:
8MB logging
50 Inputs/Outputs
Pro Logging
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
