As said , use a 90 amp, although bulk charge in any short time kills any and all batts.
3 doors where designed with there power requirements in mind.(what went wrong with fans!)
Running a 044 fuel certainly increases demand from your alternator along with high power amps etc.If the feed cable(to Batt) has seen better days and losing efficiency due to resistance/heat the situation is amplified.
I recently replaced my charging feed cable from my alternator to my battery and gained a volt over a cable distance of two metres!
Food for thought, cable is no different to a water pipe where flow=amps/current/voltage=pressure/resistance=size.
the 90a ones were harder to find when i was looking, plus there are several different fitting opetions so make sure you know what yours looks like before you shell out on one
the granada's all used the 90a version so you may have more luck there than just looking for sierra items
Electric rear windows and central locking motors can't think of anything else
If your running good power I'd use a 90amp and also if you have a decent hifi too.
I agree, if running big power go for the bigger one and uprate the lead from the alternator to the battery, I used a 2.0 mondeo alternator on my saph, it fitted quiet nice, nice and big too
