Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Fiesta Puma Conversion
Old Jan 20, 2014 | 01:19 PM
Ben Benniboi Cohen's Avatar
Ben Benniboi Cohen
Default Fiesta Puma Conversion
I am thinking of doing a Puma engine conversion on my Fiesta but wanted to know a couple of things before I do so.
First of all I have a 1.4 Fiesta with the Zetec-S engine is it a straight swap?
Second if I get one from the same year (1997) will the wiring loom plug straight in to the existing loom in my Fiesta?
Third will I need to replace the ECU?
I am going to buy a whole Puma (rusted/mot failure) as its cheaper & will have everything I need I just want to make sure I know exactly what I need as this is the first time I have done an engine swap although my dad has done one many years ago on a different car
Thanks
Old Jan 20, 2014 | 02:38 PM
lacey's Avatar
lacey
Is your Zetec s 1.6 engine any good ?
Old Jan 20, 2014 | 03:21 PM
Ben Benniboi Cohen
Its a 1.4 engine, its basically the same as the 1.6 but Ford restricted it & lowered the cc
also im not doing my conversion just yet, just want to know a bit more
Old Jan 20, 2014 | 03:55 PM
lacey's Avatar
lacey
I see .
I am after a 1.6 Zetec s engine for a project I am doing and it's easier to get turbo piston and bits for a 1.6 than a 1.7 .
I have a old Zetec s with puma running gear that I am going to break
Old Jan 20, 2014 | 04:17 PM
Ben Benniboi Cohen
Thanks but it will probably be a couple of months before im able to start the project. Will I need to buy new engine mounts or can I just use the ones from the puma donor car?
Old Jan 20, 2014 | 05:37 PM
lacey's Avatar
lacey
I had a donor puma , and just swopped it all over , so in my case no other mounts were needed
Old Jan 20, 2014 | 05:57 PM
Ben Benniboi Cohen
That's what I want to do. Did the loom plug straight in to the existing car loom?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Steve Escos
Oct 1, 2015 06:57 AM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
