Cossie management???
Old Mar 24, 2005 | 11:26 AM
B.A.R's Avatar
B.A.R
Default Cossie management???
Im after buying a cossie management kit for my s1. can any one recommend anybody that sells it, or is there any other options appart from the cossie one????
Old Mar 24, 2005 | 11:30 AM
Oranoco's Avatar
Oranoco
Gadget and Jano from here both offer conversions.
Old Mar 24, 2005 | 11:39 AM
B.A.R's Avatar
B.A.R
Cheers, dont suppose u got a number for the both of them?
Old Mar 24, 2005 | 11:45 AM
pauldudley's Avatar
pauldudley
yes mate or try and get them engine advantages on 01376502522 jano www.oodcreation.co.uk
Old Mar 27, 2005 | 08:00 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
A slight mis spell there mayteee, im sure it wasnt your fault tho
Old Mar 27, 2005 | 09:36 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
as said
Jano and Gadget
But also Karl Norris, Field motorsport and jamsport
Old Mar 27, 2005 | 10:55 AM
DazC's Avatar
DazC
Why go for Marrelli mangement and not something like Omex, DTA, GEMS, Pectel T2/T4, Emerald, Motec or Autronic? There are others, I just can't think of them at the moment.
Old Mar 27, 2005 | 11:29 AM
Ginge !'s Avatar
Ginge !
just finding my feet
depends oh what y aplication is tbh, i went for omex on my erst as its alit eaiser conversion that cossie management imo
then there are as daz said lots others
Old Mar 27, 2005 | 11:52 AM
DazC's Avatar
DazC
Not everybody has the software to map Marrelli management but aftermarket software is readily available.
The ECU I have, the software is free to download off the manufacturers website.
Martin at MEFMotorsport on here can do some cracking deals on DTA. I believe Christian or Gary at APT are Omex dealers. Mark at MAD on here is the only UK Autronic dealer....
Old Apr 5, 2005 | 08:56 AM
Versus_Creations
Ask me a question!
Dont be silly maytee, most people who deal with RS's and tunning Cossies etc.. will be able to mapp Weber. There is not a 1 Tuner i know who cant mapp weber, but if you ask them about after market management they will give you a different answer.
Weber has been around way before the cossie years and has been used in many cars from Lanica's, Fiat's, ducatti and Cosworths!!!
In fact i think that its the after market software you will have trouble getting mapped to its 100% As for downloading the software and doing it yourself ........NAH... PAY THE PRO's
Old Apr 5, 2005 | 08:59 PM
DazC's Avatar
DazC
I stand by my statement....
The software on an aftermarket ECU is far easier to get hold of than the prehistoric webber stuff....and doesn't cost. The aftermarket stuff is designed to be EASY to use where as the origional equipment (Marrelli on Cossies for example) is meant to be hard to stop you messing with it....
Who can map Webber Marrelli then?
What are you on about? Who suggested doing it yourself? I merely mentioned that the software is readily available for free on most ECU packages....
Why would there be any problems mapping an aftermarket ECU? Tuners have their preferences so are obviously going to be biased to what they like. If they can't map a system that is designed to be easy to use then should they really be mapping?
Old Apr 5, 2005 | 10:12 PM
markk's Avatar
markk
Jano_OddKidd,
ROFPMSL
daz i cant believe you think that everyone CANT map weber - it so easy and cheap to do
Old Apr 5, 2005 | 10:40 PM
DazC's Avatar
DazC
Yes! Silly me!!
Mark! I might have an ECU available. You know which one.
I might be upgrading!
Old Apr 5, 2005 | 10:50 PM
GARETH T's Avatar
GARETH T
i can name ALOT of tuners who cant
Old Apr 5, 2005 | 11:00 PM
markk's Avatar
markk
DazC,
let me know , ill then tell you if i can afford it
to what ???? s8
sorry - sorry
Old Apr 5, 2005 | 11:01 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
We can offer Omex, which is a Modern management system, with all those modern 'touches'......
Full 3D Fuel and Ignition Mapping
Lambda Control (to be released very soon)
Battery/Temp/Barometric Compensation
Antilag
Launch Control
Traction Control
NOS Control
Data Logging
Full Cold Start, Warm up and Idle Control
and much much more.
We have also just become a MoTeC dealer.
Old Apr 5, 2005 | 11:19 PM
DazC's Avatar
DazC
Originally Posted by markk
DazC,
to what ???? s8
sorry - sorry
No, to something made by the same manufacturer as the ECU I already have here! Might not happen yet though!!
Old Apr 5, 2005 | 11:24 PM
DazC's Avatar
DazC
Antilag
Launch Control
Traction Control
NOS Control
Data Logging
and much much more.
Obviously that is nothing compared to the prehistoric Webber Marrelli system!
Good old Webber is the best thing since sliced bread....
Old Apr 5, 2005 | 11:26 PM
markk's Avatar
markk
aye lad !!
put me on teh top of the list If it comes for sale
Old Apr 5, 2005 | 11:37 PM
DazC's Avatar
DazC
Your there, although the manufacturer is also interested in having it back....
Old Apr 6, 2005 | 12:18 AM
NUTS RuS's Avatar
NUTS RuS
What do you intend to do with the S1 ?
I have an aftermarket ECU fitted which easily adjusts to give me a choice of running conditions. Thats simply all done by loading in a different "map" via my laptop.
The essential base running map is very very similar, but I then have different maps to do various different things. I may turn on the "fuel on over-run" option which will give me the flames out of the back if wanted it to (very very rare). Im more likely just playing with things like at what temperature the fans cut in. If I go to an event that is tight and twisty then the fans can be called in to switch on at a lower or higher temperature as required. I have maps which wont fuel the car at all above certain revs and use this as security.
At least I dont have to keep going back to my tuner everytime I want to switch about - so thats one option worth considering if your looking at that sort of thing.
The cossie management will work and it will keep your car running well if mapped correct, but if you like learning and developing and want some toys to play with then think again.
Old Apr 6, 2005 | 12:04 PM
JesseT's Avatar
JesseT
Then there is always the Megasquirt and Megasquirt2 that will do everything mentioned above and cost around 100Ł.
Old Apr 6, 2005 | 12:35 PM
Gadget's Avatar
Gadget
Spanner monkey
I have just spoken to someone who has the whole lot for sale very soon, Paul Ripley off of here, he's going down the pectel route so has everything you need, and it's from a running engine so has all the mapping done, all you'd need is the final check on the mapping to suit your car!!
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
griffo69
Oct 4, 2015 11:58 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
