Fuel pipe to rail
Old Jan 18, 2014 | 02:34 PM
cossie891's Avatar
cossie891
Default Fuel pipe to rail
Where can I get the correct tool to remove the fuel rail
Old Jan 18, 2014 | 03:18 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You don't need a proper tool. Just cut a small length of cooper pipe and cut it down the middle.
You just push it into the spring clip then pull it apart
Steve
Old Jan 18, 2014 | 03:19 PM
cossie891's Avatar
cossie891
Ok cool cheers mate
Old Jan 18, 2014 | 03:30 PM
cozzy jeff's Avatar
cozzy jeff
check out the post number 10.
https://passionford.com/forum/ford-s...t-options.html
Old Jan 18, 2014 | 03:39 PM
cossie891's Avatar
cossie891
Perfect I get it now
Old Jan 18, 2014 | 03:45 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I have been looking for my bit of pipe to show you, but the above post shows you.
Steve
Old Jan 18, 2014 | 03:52 PM
cossie891's Avatar
cossie891
Cheers Steve I will change mine over monday
Old Jan 18, 2014 | 07:32 PM
BRAMMER's Avatar
BRAMMER
I used a small jubilee clip with the screw cut off and pushed inside, same idea as above
155lee
Sep 6, 2016 11:10 AM
steve.rst
Mar 15, 2016 08:01 AM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
