Powder coat help on me saph
Hi guys, I need a bit of help
I've stripped everything from the underside of me saph cos, & I need to know exactly what I need to send off to powder coat????
Sorry to b so anal but I'm a bit clueless as never done it before!!!!
And also do I need to cover all thread holes, & where the wheel bearings go, plus do I leave the expensive bearings in on the rear arms while being powder coated?? It's having all new bushes & I know them are the only ones you don't change.
Thanks Lee
Thanks Lee
makes sure you do mate as if not its a pain in the arse , I bought a hub that a guy had done but never removed anything studs covered over , bearings in the hub full of shot blasting grit / beads , not good
