Escort cosworth turbo gauge "underlight"
Old Jan 14, 2014 | 03:00 PM
midnight_man's Avatar
midnight_man
Default Escort cosworth turbo gauge "underlight"
Hi,
my gauge (turbo pressure, oil pressure, battery volt) is not lighting . I thing that there is some AC power....but I have no idea how is it working.
Can somebody explain me? Whatever I can find a problem.
Thanks!
Viktor
Old Jan 18, 2014 | 08:26 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
The battery volts and boost gauge etc work from an invertor inside the clocks on the dash. If you take the clocks apart it is possible to buy a new invertor from the likes of RS components and solder a new one in.
Worth doing, otherwise you will need another set of dash clocks which will cause more agro with miles not matching and you never know if another set of clocks will fix it.
Old Jan 18, 2014 | 07:52 PM
dave cos4x4's Avatar
dave cos4x4
go on the 'escortrscosworth.com' forum and Cozzed on there will be able to fix them.
Old Jan 18, 2014 | 09:11 PM
midnight_man
I solved this problem on 2 hours..... I re-soldered all connections on board (there was missing +12V for invertor).
I pug in all into car....it was lighting few hours and then dead.
Now when I unplug the rear connector from instruments and plug it again it will light for few hours and then get off. I must again unplug and plug the rear connetor. I tried only move with cables going out of connector (but without result).
I dont understand how disconnecting the connector can make this...
I can be wrong invertor or there is still somewhere wrong connection on DC 12V?
thanks!
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
Vincereese
Aug 16, 2015 06:38 PM
muz
Aug 16, 2015 12:57 PM
Old ford
Jul 31, 2015 06:50 AM
