Ford Range This section is for other models in the Ford range.
Scorpio Rear cross member
Old Jan 10, 2014 | 07:24 PM
Zim 3's Avatar
Zim 3
Default Scorpio Rear cross member
Hi,
I hope I am posting this in correct section. I have a 1997 Scorpio Ultima Estate which needs a new rear cross member. A lot of the spares have been the same as the Ford Granada but my mechanic is not any good online. The Ford Spares place he uses have girls that do not have a clue. Does anyone know if the Granada one is the same as the Scorpio. I checked out the Sierra and some have used the Scorpio one on their Sierras but I can't find it the other way around. I believe the Sierra floor pan is narrower?
I would love to keep this car running as it is pretty rare now and only 81,000 on the clock. A load of work done in the last 2 years.
The whole Granada/Scorpio name gets confusing around the Mark 3
Zim 3
Old Mar 31, 2014 | 03:09 AM
Larry Semon's Avatar
Larry Semon
The part/s you will receive will be manufactured by Delphi. When and only when Delphi UK are themselves are out of stock, we will supply First Line, ADL Blueprint, Trupart or FAI. (in order of availability) - all are leading brands and manufacturers of quality suspension components.
rex647
Mar 6, 2022 06:20 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
Tony W
Sep 9, 2015 12:08 PM
cossirob
Sep 3, 2015 09:17 PM
