Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Lowering Springs Hard to find?
Old Jan 10, 2014 | 04:14 PM
Cardie's Avatar
Cardie
Default Lowering Springs Hard to find?
Im struggling to find a set of lowering springs for my MK1 Focus Estate, Its on Mondeo ST24 Alloys but it sits just a bit too high for my liking, though it seems to handle brilliantly!
I dont want it slammed on its arse I just want it to look that bit more 'standard' probably lowing 40mm or 60 at a push as I dont want to ruin the ride.
Are the suspension systems differnt at the back on an estate than a hatchback?
The absaloute LAST resort is cutting them, some can be done this way but I'd rather not for obvious reasons.
Tar!
Old Jan 10, 2014 | 05:45 PM
Sinbad's Avatar
Sinbad
PM slammedorion mate as he has lowered his, also check out the Focus Estate Thread in the pics section
Old Jan 10, 2014 | 05:48 PM
Look up st170 estate, as the springs off one of them may suit you ,I would think they would be lower than standard
Old Jan 10, 2014 | 05:50 PM
just looked .lots of new lowered spring kits on ebay for focus estate on ebay
Old Jan 10, 2014 | 05:53 PM
Bailes1992's Avatar
Bailes1992
Tried Ford? They should be able to supply Eibach Pro-Kit springs.
It's what I fitted to my Mondeo. They're progressive so don't ruin day to day comfort.
Old Jan 10, 2014 | 07:28 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
http://www.dfaulknersprings.com/
Will make you a pair from about £70, just tell them what you want
Old Jan 10, 2014 | 10:45 PM
Cardie's Avatar
Cardie
Thank you very much I will have a look around!!
Old Feb 6, 2014 | 12:58 PM
bigbhu's Avatar
bigbhu
[quote=Cardie;6405662]Im struggling to find a set of lowering springs for my MK1 Focus Estate, Its on Mondeo ST24 Alloys but it sits just a bit too high for my liking, though it seems to handle brilliantly!
I bought a set of 40mm drop springs off ebay, i think they were Apex not sure, they sit nice and are not too soft or too hard. I did have coil overs on it with a 100mm drop, with 16inch stanadrd wheels the top of the alloys was level with the top of the arch! lol
Then the mrs said sort "sort ya sh"t out" then i went for 60mm springs which have been approved by the mrs lol
the only diffrence on the estate is the rear shocks, they are mounted at approx 40ish degree angle to the rear subframe/ axle and are alot shorter and stiffer due to the higher load over the back wheels.
below is how it sits now, probley do with a 45 profile tyre rather than a 40.
http://i1373.photobucket.com/albums/...ps082ae71f.jpg
below is about 70mm drop on coilover, i managed to drop it to 100mm and then it was way too uncomfortable lol
http://i1373.photobucket.com/albums/...ps1fa97dc1.jpg
jamie956
Sep 1, 2015 10:50 AM
Ben26
Aug 27, 2015 08:56 PM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
A.t.p
Aug 15, 2015 11:37 AM
RsS2daz
Aug 14, 2015 05:26 AM
