Puma engined KA.
Old Jan 10, 2014 | 03:16 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Default Puma engined KA.
my daily drive is dead so i need a new car.
Sportka's are pennies now and ive had one before but you have to nail them everywhere to get the best out of the handling. Not that i have a problem with that.....
I also used to have a KA with a RS1800 zetec in and that went really well.
So im thinking sticking a puma lump in the Sportka, perhaps heavy head mods, throttle bodies and a decent diff and it should be 170bhp of comedyness leaving 2 black lines everywhere should you so wish.
Anyone on here got experience of fitting the puma lump??
There used to be a company that did off the shelf engine mounts for the zetec SE engine for a KA called trackdesigns but they dont seem to be about any more.
Anyone know what needs to be done mounting wise or where i can get pre-made mounts??
Also any experts on the ka/fiesta mk3.5 front chassis legs and differences between that and mk4/puma chassis legs.
From what i can see the ka is based on fiesta 3.5 subframes for each wishbone with an extension from the chassis leg to mount the rear of the subframe. on the mk4/puma the subframe is joined in middle and the extenstion has been moved from chassis leg to subframe. So im thinking if thats the main difference but other than that the chassis legs are basically similar then how feasable would bolting up the puma subframe be with a few modifications with a grinder??
Using the puma subframe makes all the gearbox and drive shaft compatability issues go away plus its a better set up.
Old Jan 10, 2014 | 03:30 PM
bagginsRSturbo's Avatar
bagginsRSturbo
Sounds like an awesome project. Going to be alot of fun for sure .
Could you not use a fiesta/puma mount as there the same I think
It should fit in no probs as the fiesta/puma/ka are quite the same
Old Jan 10, 2014 | 03:50 PM
wide ka's Avatar
wide ka
yes i did a 175bhp 1600 zetec se ka,
i used the ka box with the se bellhousing, needed a uprated rear mount as the power rocked the engine alot, i made the n/s mount from scratch to the original pickup points on the chassis leg.
id use the 1600, cheaper, more around nothing in there power wise really between the 1.6 and 1.7 and no vct hassle if going aftermarket
Old Jan 10, 2014 | 03:54 PM
st220kyle's Avatar
st220kyle
Will you do a build thread this time? I remember you posting a pic of your last ka and the Speedo going off the clock haha,but sadly no pics of it being put together
Old Jan 10, 2014 | 04:03 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
I want to see this!
Old Jan 10, 2014 | 04:05 PM
Paul_RS's Avatar
Paul_RS
See highlighted - Do nothing to car
Old Jan 10, 2014 | 04:17 PM
Psycho Warren
Carbon Crazy
unfortunately not as there was a complete change of subframes at the front end between fez 3.5/ka and mk4/puma shells.
I want to avoid fucking about with the boxes too much if i can avoid it. - hence the subframe idea.
Ive had a 1.7 on throttle bodies with VCT before no problem. I dont see VCT as a disadvantage really as long as you dont have a poverty spec ECU controlling it!! Plus the engines are cheap enough in either 1.6 or 1.7 guise.
Originally Posted by CrOwSoN15
I want to see this!
4 up too
Ran out of "private runway" so i reckon it might of got 140.
that would be no fun.
Old Jan 10, 2014 | 04:27 PM
bagginsRSturbo
Is there a thread on the 1800 ka ??
Old Jan 10, 2014 | 05:08 PM
Psycho Warren
Carbon Crazy
Sadly not. It was another run around at the time
Old Jan 10, 2014 | 06:33 PM
bagginsRSturbo
Thats a shame bet it was fun thou
Old Jan 10, 2014 | 09:47 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
I think a 1700 Puma engine in a Ka would be awesome fun
Old Jan 11, 2014 | 06:51 AM
STeve's Avatar
Super Moderator
girl in my road has a streetka with a puma engine, goes like a rocket
Old Jan 11, 2014 | 08:35 AM
Sounds good Nutty Warren. Wasnt there a Ka in ff mag year's ago with the poooma engine in.
Old Jan 11, 2014 | 11:09 AM
Brendan's Avatar
Brendan
struggling with reality
I have a very good set of wiring diagrams for a mk4 fiesta! I can send them to you if you want!
Old Jan 11, 2014 | 12:57 PM
Psycho Warren
Carbon Crazy
Ive got the TIS disc so should be ok gor wiring.
Plus a streetka is over 100kg heavier than the sport due to the gay roof.
Old Jan 11, 2014 | 01:25 PM
Mk4 Rick's Avatar
Mk4 Rick
Im looking forward to the build
Old Jan 11, 2014 | 01:34 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Streetka.......
Never
Old Jan 11, 2014 | 02:08 PM
Bentleya's Avatar
Bentleya
I can't help you with anything you have asked for Warren, it's a shame your Shogun is dead .
Look forward to following progress with this.
Old Jan 11, 2014 | 06:03 PM
st220kyle's Avatar
st220kyle
I assume you are using the sportka box? if so what are your thoughts on the puma engine - sportka box, Are you not put off by the low ratios?
Old Jan 11, 2014 | 10:01 PM
Psycho Warren
Carbon Crazy
Kyle the aim is to use puma box and subframe the lot. Requires a bit of chassis leg modding to bolt up but from the basic measurements in the scrappy, it should all fit up ok. The key bolt distances for the rear of the subframe are strangely the same lol. good old fords. main difference is the subframe had a mount cradle on the bottom of chassis leg on mk3.5/ka shell, where as later cars they ditched it, put a captive nut in and the extension became part of the subframe instead.
Old Jan 11, 2014 | 11:37 PM
studabear's Avatar
studabear
Good luck finding a none rotten Ka, worthy of doing the conversion on.
Old Jan 12, 2014 | 08:53 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Exactly what put me off building a ZT ka, all cheap ones are rotten as an orchard.
Old Jan 13, 2014 | 08:13 AM
Psycho Warren
Carbon Crazy
Its a ford, rust is to be expected - especially as its based on a mk3 fiesta - the king of rust in ford circles!!
Old Jan 13, 2014 | 08:19 AM
STeve's Avatar
Super Moderator
had a drive of that puma powered KA yesterday and I was impressed and as you mention its heavier too, her boyfriend did the work and also installed the puma box and fitted rear discs etc
Old Jan 13, 2014 | 08:40 AM
Psycho Warren
Carbon Crazy
Well I've placed a deposit on a sportka now. Spending a grand total of Ł750
No rust that will fail the MoT yet, and nothing thats on panels that i cant easily fix/make out of carbon anyway.
Old Jan 13, 2014 | 09:01 AM
STeve's Avatar
Super Moderator
I spotted this puma powered KA on a old PF thread
Old Jan 13, 2014 | 09:28 AM
Psycho Warren
Carbon Crazy
There's plenty of them about, no one seems to have documented much about mounting them. Don't know why its such a secret. I know the conversion used to cost like Ł4.5k but that was some time ago.
Old Jan 13, 2014 | 11:23 AM
I could do with a wiring diagram for the interior boot switch on a mk4 fiesta.
Old Jan 13, 2014 | 12:36 PM
st220kyle's Avatar
st220kyle
Ah I see, will that be a first then or is that the norm to swap subframe and box?
Ł750 is that all??? They appear cheaper than a basic ka. I guess that's due to higher running costs.
Old Jan 13, 2014 | 01:06 PM
Psycho Warren
Carbon Crazy
most people use the KA gearbox casing to make the gearbox mounts standard KA. However, i'd rather use puma mounts and box and hubs etc as it makes everything simple like puma drive shafts etc throughout rather than bodging things. Mixing and matching just makes it more complicated.
Old Jan 15, 2014 | 11:51 AM
fury556's Avatar
fury556
ST170
The only useful info I can add is that you might need to chop the slam panel as the cam pulleys would foul otherwise. I know that's right for the standard Ka, and presume it's the same for the SportKa.
I've seen that Ka in the flesh, bought my roll cage and exhaust off him very tidy conversion.
Old Jan 15, 2014 | 01:21 PM
Psycho Warren
Carbon Crazy
nothing i cant sort with an angle grinder
Only thing im thinking of is can i move the alternator lower and keep same belt? or is there a smaller race alternator that will fit? Might free up some space.
Old Jan 15, 2014 | 02:16 PM
Dal_'s Avatar
Dal_
Warren,
Check this out:
http://www.projectpuma.com/viewtopic...4&t=840&p=9113
I can give you his email if you need to ask questions
Old Jan 15, 2014 | 03:05 PM
Psycho Warren
Carbon Crazy
Seen plenty of photos of that car on kaklub. He didnt fit the engine himself so not greatest help on that front.
Old Jan 15, 2014 | 03:20 PM
wide ka's Avatar
wide ka
puma shafts dont fit the ka hubs, not sure if the puma hubs will take the ka shock think they should.
what ecu are you going to use?
Old Jan 15, 2014 | 06:41 PM
Psycho Warren
Carbon Crazy
Using puma hubs. Shocks fit fine plenty of KA ford racing suspension kits fitted to pumas.
I might even be able to keep the ka subframe and modify the lower arm holders to take the puma arms with a bit of welding. All the measurements like distance between lower arm on each side (bolt points) are funnily enough the same. So even the geometry basics are scarily similar. The sportka already has a lower cross brace between the lower arms and if converted to later arms, can fit a lower strut brace.
Im modifying the puma engine going in it to be on throttle bodies so likely to be aftermarket management although not decided who's yet.
Old Jan 17, 2014 | 05:19 PM
moondustka's Avatar
moondustka
Boooost!
Got to say, and not being rude there is some false information on this thread..
Puma shafts do fit Ka hubs, but are the wrong length.
It's much easier to bolt a Ka box with puma bell housing to the puma engine. I would imagine that the subframe would be quite challenging to fit to a Ka. The Ka is based on a mk3/3.5 fiesta.
It's a relatively easy conversion although not done it myself. But I have done the fiesta turbo conversion and after that put the FRS engine in one.
Old Jan 17, 2014 | 08:49 PM
Psycho Warren
Carbon Crazy
I dont intend to use ka hubs or wishbones so cv size and driveshaft length is irrelevant.... thats why i want it all puma upfront. less complications to maintain.
The mk3 fiesta floorpan is significantly different to mk3.5 Mk3.5 is basically the development mk4 floorpan. Aft of the engine bulkhead, the floorpan is virtually identical to mk4 fiesta upto turret hieght. Even the seat mounts fit etc. The front chassis legs are modified from mk3's and an interim for the older engine packages of the mk3/3.5 compared to the mk4.
The front subframe bolt centres are the same in many key places as are wishbone pivot dimensions and ARB locations
Old Jan 18, 2014 | 08:49 PM
moondustka's Avatar
moondustka
Boooost!
Fair enough.. Looks pretty different to me, but maybe I'm wrong. When I came to the puma I found a fair number of differences that held me up.
Engine bay is different - chassis legs etc.
So do you plan to have a wider track at the front? I'm just confused with why the driveshaft length doesn't matter? Puma hubs make up the difference?
Old Jan 18, 2014 | 09:05 PM
Psycho Warren
Carbon Crazy
As said the chassis legs are more mk3 than mk4, primarily the front mount for the subframe is on a weld on drop mount on the mk3/ka. on later mk4 they ditched it, and put a raiser on the subframe instead.
Theres other differences, eg on ka, rack is mounted to bulkhead, puma its on the subframe. Not a problem, can be left where it is. also lower gearbox mount is on chassis on KA, but on subframe on puma. The puma and ka lower mounts are different anyway. Conveniently the sportka has a lower cross brace in a close enough location to mount the gearbox mount if i cant fit the puma subframe.
driveshaft length doesnt matter if im using componants all from one car as they will match up.
