Ford Focus (All Models)This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
In the process of making my own inlet manifold, will be using the st170 manifold for the injectors, just need a few more bits and ready to start welding, will hopefully be able to use a standard idle control valve with it and will have all connections for the vac hoses.
That's a good question, stainless is easily available to me through work as we don't use much aluminium. Might make another one some day and will try ally next time
IIRC the port spacings are completely different, I'll try and get a picture to confirm for you tomorrow as it's been years since I've looked at Zetec engine bits
Oh, I'd be very surprised if that is the case as many people have used them without issue. A picture would be great, thank you.
Ah well I can't see it being unusable and making any difference at all, I'm going to be porting my head and will be useing a dremel to port the st170 inlet manifold and will do my best to line them up, thanks for taking the time to tke the picture mate, cheers
