what current tyre looks like d40?
As title, what modern tyre can I buy so that the tread pattern looks like a Dunlop d40? To go on standard lattice wheels 205 50 15.... ?? Cheers
you're quite limited in your choice if you're after the standard 205/50/15's.
I eventually narrowed my choices down to Continental, Toyo or Dunlop
Decided to go with the Dunlop Sport SP01 purely because they're as close to original as you're likely to get these days. Even though the tread pattern's not the same as the original D40, you've still got the original manufacturer tyre fitted. Could get them for about £75-80 per corner
