knocking sound when turning right
Old Jan 7, 2014 | 05:07 PM
gazlet's Avatar
gazlet
Default knocking sound when turning right
Hi all a bit new to this have purchased an st 220 and there is a slight knocking sound coming from the front which gets louder when i turn right i have been told that it could be the drive shafts or the wheel bearings any advice would be appreciated.
Many thanks
Gary
Old Jan 7, 2014 | 05:22 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Wishbones?
Old Jan 7, 2014 | 07:20 PM
dojj's Avatar
dojj
Resident Wrestling Legend
it'll be the cv joint
not sure if you can get them seperatly, most places will give you the whole shaft from memory
although it could also be the drop links, which are about a fiver each and take minutes to change
Old Jan 8, 2014 | 05:45 PM
gazlet's Avatar
gazlet
Thanks for the reply will look into it
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
