FIAT FORUM
Rich, i bought a gt turbo for a run about & im suprised as it's quite nippy for a 1.4
abdr500, it's got a slight oil leak from the gasket but it aint the rocker cover gasket it's the one under that?????
I can see the bolts on the back but not the ones on the front????
Does that make sense?
We have a punto site over here in Holland, but it's all in Dutch :
http://www.puntosportivo.nl/
Then I found this on Google:
http://www.puntoforum.co.uk/
thers also bolts in side the cam box so you will need to remove the cam cover and you should see 5 bolts ther gona be coverd in oil but most inportant ther 1 behind the timming belt cover the black plastic cover you must remove that one . be sure the shims dont get mixed up as ther not hydrolic ther shims so they must be put back the same way if you need any parts let me no
will let u know when he replys!
