OK ANYONE KNOW ABOUT VAUXHALL 2.0 16V ENGINES ECT
Old Mar 23, 2005 | 07:24 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default OK ANYONE KNOW ABOUT VAUXHALL 2.0 16V ENGINES ECT
im gonna assist a mate with his nova conversion and when looking at the loom theres loads of ecu's everywhere
just wondering who knows what there for and whats what,
they all got codes on em, just wondering if ya can tell me what the igniton amp is and what else i might need for it
Old Mar 23, 2005 | 07:27 PM
Red16's Avatar
Red16
cue Chip
Old Mar 23, 2005 | 07:28 PM
Rhys's Avatar
Rhys
Yup Chips your man on this one
Old Mar 23, 2005 | 07:30 PM
Nath's Avatar
Nath
Or Craig/Moose130 hes just churned out a few of them recently
Old Mar 23, 2005 | 07:33 PM
JamesR's Avatar
JamesR
The loom comes in two halves:
1: the car electronics side
2: the engine.
You should only need to remove the engine loom, this is located down the driverside of the Cavalier, with the ECU bolting to the inner of the bulkhead.
Just mark up/photograph the wiring plugs/connections when you remove them from the engine. Then remove the engine loom.
You should be left with a smaler section of loom and wont have the alarm ecu, 4wd ecu or anything of that nature.
hope that helps??
Old Mar 23, 2005 | 07:34 PM
Ginge !'s Avatar
Ginge !
cheers guys, now wheres chip when ya need him
wonder if i close my eyes and call out " i hate nitrous" 3 times loud he will hear and come on line to defend the cheating agent
Old Mar 23, 2005 | 07:37 PM
Ginge !'s Avatar
Ginge !
looms in a box and theres a loom on the engine already
does that mean i lob the loom in the box in the bin or not
oh its going in a 1.3sr nova btw with a lcd dash already bodged in
if its all techy i dont mind doing it via msn
cheers for ya help btw
i bought haynes manual for the conversion but it seems that its no use either
Old Mar 23, 2005 | 07:43 PM
JamesR's Avatar
JamesR
No probs. Ignore the loom in the box. i presume that is what you have been looking at a "bricking it"
You should only have the engine loom and a big black multiplug that basically connects with the ecu at one end. The other end should be the spade connections for the earth points and battery connections.
The 1.3 sr should be fine as there is no needless wiring to get in the way as it carb fed.
The digi dash should be easy enough to connect up, there are more power and earth connections. It is just a caso of using the GTE g/box transducer and mating up the appropriate wires for it.
Old Mar 23, 2005 | 07:48 PM
Cowboi's Avatar
Cowboi
digi dash is wired up already and working, except its over reading on the speedo.
on the engine loom there is the big plug which we understand, and a few other connectors branching off the big set of wires. im guessing they are the bits that need connecting up to the nova loom
Old Mar 23, 2005 | 07:49 PM
Ginge !'s Avatar
Ginge !
cool
so the round multi plug is what connects it, and what wires do i then connect to make the ecy power up
and what does the ingnition amp look like too
, erst looms are fooking piss after this one
i looked in the box and theres 5 fooking extra modules and no fooking discription of what they are
Old Mar 23, 2005 | 07:52 PM
Ginge !'s Avatar
Ginge !
cowboi, get back in ya pit, this is now my project
your job is the techincal stuff like making the tea of feeding them horse size rabbits
ya should have buried that fooking cat in the concrete too when ya had the chance too
now back to my new hobby
Old Mar 23, 2005 | 07:57 PM
JamesR's Avatar
JamesR
If the clocks are over reading you can "try" flicking the lil red switch on top of the clocks, think its hidden at the back in a central position. This affects how it reads. Failing that did the transducer come out of the same car as the clocks?? as there a re a few different kinds
Will be back in a sec
Old Mar 23, 2005 | 07:59 PM
Ginge !'s Avatar
Ginge !
no dont go, we need your help
if ya live local fancy poping round one evening for payment in stellas and pizza
ya can even eat one of the rabbits
Old Mar 23, 2005 | 08:04 PM
JamesR's Avatar
JamesR
If this doesnt help you, nothing will
http://www.valvers.com/20xe/downloads/20xenova.pdf
HTH??
Old Mar 23, 2005 | 08:07 PM
Ginge !'s Avatar
Ginge !
need adobe first
Cowboi's Avatar
Cowboi
i forgot to tell u, there is a paw print in our concrete, and the rabbits have been removed from MY garage.
i'll remind u that all i do is make tea next time u want your exhaust sorting out.
ive flicked the red switch, i think it was from the same car, it seam to work ok on my mates sri nova, just not mine. im hopinh it will be better with my new engine.
Old Mar 23, 2005 | 08:08 PM
Cowboi's Avatar
Cowboi
i sent u the normal version of that ginge. its pretty good. i will print it at work 2mora and give u a copy
Old Mar 23, 2005 | 08:09 PM
JamesR's Avatar
JamesR
b19bal - your not making life easy for me here
Get adobe and fir an XE in your sleep then
Old Mar 23, 2005 | 08:10 PM
Ginge !'s Avatar
Ginge !
need my zorst looking at again when i can be arsed, keep meaning to mention it, where we cut it very tight it rattles on the chassis
think we need a new bodge but we got the nova to cut and shut first Teaboi
Old Mar 23, 2005 | 08:12 PM
Ginge !'s Avatar
Ginge !
yeah print it off and give it too me, unless i can download at work
im gonna do this conversion then the next post will be calibra turbo conversion
whats all the other ecu's for btw
Old Mar 23, 2005 | 08:14 PM
Cowboi's Avatar
Cowboi
its Cowboi.
we will put some flexi pipe on ur zorst. round that bend, hopefully that will fit better and stop the rattles.
im gonna read that guide again now and see if it makes more sense now ive looked at the actualy loom. before i was reading it blind.
cheers for the help james. fell free to come and use my pit if u need too!
its in chingford, dunno if thats a bit of a mission from u.
Old Mar 23, 2005 | 08:15 PM
JamesR's Avatar
JamesR
My old cavalier Turbo, there were alarm ecu, 4x4 ecu, relays, dianostic (lights on dash) ecu. A load of nonsense you will gladly not get involved in, when your fitting the XE
Old Mar 23, 2005 | 08:17 PM
Ginge !'s Avatar
Ginge !
bewarned james, theres a cue and hes curantly taking bookings after the new year now
this is gonna be a fun weekend
if the looms all self contained then its easier than the hayne manual makes it look
i was looking foward to ripping the loom apart and fitting it as a subloom too
well was fun doing my cabrio engines one
Old Mar 23, 2005 | 08:21 PM
JamesR's Avatar
JamesR
Cheers Gents, i actually live near Manchester.
But even if i lived 2 minutes away from you bodgers i would tell you i lived in Glasgow
hehehe good luck and let me know how it goes.
Old Mar 23, 2005 | 08:23 PM
Ginge !'s Avatar
Ginge !
manchester hey
well in that case we better lock the garage then
just kidding, manc aint far is it , my cossie come from manchester , never took long to get back to london either
Old Mar 23, 2005 | 08:24 PM
JamesR's Avatar
JamesR
Well it wouldnt would it with your heavy boots on
Nice car BTW
far better than a nova, i have had far too many novas.
Old Mar 23, 2005 | 08:25 PM
Cowboi's Avatar
Cowboi
we may sound like bodgers, and my name dont help matters, but we are dedicated, educated and clever blokes. :blonde: ha ha
ur cabrio will be done soon mate, u gotta let me take the cossie for a drive if i let u do that in the garage surley
Old Mar 23, 2005 | 08:26 PM
Cowboi's Avatar
Cowboi
trust me, ginge aint got heavy boots. heavy tits maybe
Old Mar 23, 2005 | 08:29 PM
Ginge !'s Avatar
Ginge !
Nice car BTW
ya aint seen it yet , photoshop is a wonderful thing
cheers for the comment but im sure the nova is more fun to drive ( and cheeper )
i dont know why but i actually like novas now for some reason
cowboi ya can drive the car when hayden finishes the cabrio or pikey washes ANY of his cars
trust me its not all that , just a nice thing to stand beside and say " look i got a cossie "
Old Mar 23, 2005 | 08:30 PM
Ginge !'s Avatar
Ginge !
, but im married off now so no need to make a effort
wait till the missus reads that , ill be living in ya pit
Old Mar 23, 2005 | 08:32 PM
Cowboi's Avatar
Cowboi
pikey always washes his fiesta, but it is so rusty it always look dirty.
hayden is selling his cab.
u may as well just let me drive it so i can park it and say "look, ive got a cossie"
JamesR's Avatar
JamesR
Whats all this Ginge, i aint no giner lmao
Cowboi's Avatar
Cowboi
you can come and sleep with the rabbits when she kicks u out
Old Mar 23, 2005 | 08:33 PM
Cowboi's Avatar
Cowboi
b19bal is ginge
Old Mar 23, 2005 | 08:38 PM
Ginge !'s Avatar
Ginge !
hey nothing wrong with ginger people id there cowboi
cowboi when i feel confident enough that my car aint gonna blow up ( just after hells freezing piont is at a all time low) then ya can drive it
remember its not just my car but the missus as well , shes has the final say
Old Mar 23, 2005 | 08:42 PM
Cowboi's Avatar
Cowboi
i'll buy her a me 2 u bear from clintons. all girls love them and im sure i can drive HER car then.
there certinally aint nothing wrong ginger people
Old Mar 23, 2005 | 08:45 PM
Ginge !'s Avatar
Ginge !
unless they canr say " dunkers " or " book"
Old Mar 23, 2005 | 09:11 PM
tonysr's Avatar
tonysr
Red connects to ignition live
Red/Blue to fuel pump relay
Black to earth
Thats the ecu loom wires IIRC but dont count me on that
Old Mar 23, 2005 | 09:13 PM
Ginge !'s Avatar
Ginge !
need a perm live
Old Mar 23, 2005 | 09:27 PM
Cam's Avatar
Cam
cue Shonky.......
