Anyone clued up on a cossie YB water piping system?
Old Dec 20, 2013 | 06:47 AM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default Anyone clued up on a cossie YB water piping system?
My cossie i have blocked the pipe that goes from my water pump to to the metal pipe that goes to heater matrix (as its a track car so no heater matrix) and ive also blocked the part at the back of the engine were it goes to near water sensor.
is this a problem ie its not actually needed is it the part of the circulation? as i blocked it will proper weld?
Old Dec 20, 2013 | 07:06 AM
Ridgey's Avatar
Ridgey
Take it your not running modine (oil/water) heat exchanger?
Old Dec 20, 2013 | 07:27 AM
Roosie's Avatar
Roosie
No mate im not.
Old Dec 20, 2013 | 07:48 AM
BIL N KEL's Avatar
BIL N KEL
Basically you want to remove the heater and oil cooler. I wouldn't blank these off but instead run a hose direct from water pump to back off head.
I may be wrong but surely blanking them off would effect the water circulation of the engine????"
Old Dec 20, 2013 | 07:53 AM
jamie956's Avatar
jamie956
You are right you must connect the water pump to the back of the head as it traps the water there and can boil it,
Old Dec 20, 2013 | 08:07 AM
Roosie's Avatar
Roosie
Ive wellded a bung straight on the warter pump and on the fitting at back so there is no trapped water as such but didnt know if water still circulates without it?
best think i can do is keep checking the temp.
Old Dec 20, 2013 | 08:16 AM
Touring Car Spares's Avatar
Touring Car Spares
It'll be fine thats how ive run every Race car for years.
Old Dec 20, 2013 | 08:22 AM
Touring Car Spares
You can see the Thermostat housing blanked off in this picture, you must bleed back to the header tank tho , I do this from the front part of the Thermostat housing and also from the swirl pot , not too big a bore tho !
I feed into the bottom hose between rad and hose,its the coldest part of the system .
155lee
Sep 6, 2016 11:10 AM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
jay030787
Sep 18, 2015 04:38 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
ST-170
Sep 4, 2015 11:02 AM
