Clunking noise 3dr
Old Dec 13, 2013 | 04:10 PM
V8ish's Avatar
V8ish
Default Clunking noise 3dr
Every so often I get a consistent clunking/thudding noise that increases with the revs.
To give you an idea, the clunks happens akin to every revoution of the wheel at around 20mph then gets faster until it blurs into one. Then I'll slow down to check again and its gone??
If I dip the clutch the noise goes (whenever I can get it to do it).
Any ideas? with it being consistent its got to be drive chain related?, I originally thought the propshaft might have been catching something, but even doing 5mph that would be a clunk, clunk, clunk rather than a clunk..............clunk..........clunk if that makes sense?
I've jacked it up but can see a thing? Any ideas?
Thanks
Old Dec 13, 2013 | 06:05 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Check the prop,dohnuts, UV joints
Old Dec 13, 2013 | 06:34 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Years ago i had a thumping noise that increased with revs but went when full bore
Checked loads of drivetrain parts, replaced prop
Ended up being exhaust downpipe hitting anti roll bar...
When I first looked at downpipe it looked clear but obviously not..lol
Old Dec 20, 2013 | 05:19 PM
david 100's Avatar
david 100
Check the allan bolts on the drive shafts, inner and outer, I had 2 screew out on there own causing a clucking noise.
Old Dec 20, 2013 | 05:43 PM
boy-racer-1's Avatar
boy-racer-1
sounds like a loose flywheel bolt to me but could be anything
gingeRS
17
Oct 2, 2015 09:42 AM
martynhomer01
Oct 1, 2015 12:05 AM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
talon1
Sep 15, 2015 10:27 AM
rsturbo27
Sep 5, 2015 05:08 PM
