Fuel line replacement part options
Old Dec 12, 2013 | 04:54 PM
adam151082's Avatar
adam151082
Default Fuel line replacement part options
Rite, this joint is giving me a rite head ache as i cant seperate it, and if i do i dont fancy re-using it.
So what do you lads do if you need to replace it?
Buy the same part again or upgrade to somthing else?
And how do i remove the other end on the fuel rail?
Old Dec 12, 2013 | 06:53 PM
cozzy jeff's Avatar
cozzy jeff
Adam to remove the fuel rail end of the pipe cut through one side of a 15mm copper olive and push it up the fitting to push the spring apart then pull on the hose I should pull out with a god pull, hope what ive said makes sense.
Old Dec 12, 2013 | 07:26 PM
adam151082's Avatar
adam151082
Thanks Jeff, ill give it a go tomorrow.
Did you replace this part on yours or put somthing else on?
Old Dec 12, 2013 | 08:47 PM
cozzy jeff's Avatar
cozzy jeff
I had jic fittings welded on mate, im gonna use braied hose
Old Dec 12, 2013 | 10:28 PM
Paul_RS's Avatar
Paul_RS
There's a special tool needed to release the fuel rail fitting.
Old Dec 12, 2013 | 10:48 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Chop the ends off the braze dash fittings on
Old Dec 13, 2013 | 04:03 PM
adam151082's Avatar
adam151082
I dont fancy getting things brazzed on m8, just more to go wrong and more work.
Does anyone know if theres much preasure in this pipe?
Could i jubile clip abit of fuel line hose on here?
Its holding me rite up this bloody fuel line, Fords no longer stock this part.
Old Dec 13, 2013 | 04:16 PM
ajamesc's Avatar
ajamesc
Dash fittings brazed on are fit and forget so not more to go wrong!
But it's only pump pressure so a hose clamp will be fine I've seen a few like it but not ideal really as I don't think there's a flare in the pipe for the hose clip to clamp up before
Old Dec 13, 2013 | 05:07 PM
Mark Shead's Avatar
Mark Shead
Yes but it can be removed easy.
Mark
Old Dec 13, 2013 | 06:53 PM
cozzy jeff's Avatar
cozzy jeff
How did you get on today mate did you manage to get the fuel rail side removed?
Heres a pic to show what I was on about earlier.
Old Dec 13, 2013 | 09:07 PM
Mark
How is removed then matey.
Old Dec 13, 2013 | 09:12 PM
Mark Shead's Avatar
Mark Shead
In pict above shows you type of tool. The other pipe you either have a tool to push up in slots then push and pipe comes off or pull cover off and push the ring.
Mark
Old Dec 13, 2013 | 09:43 PM
adam151082's Avatar
adam151082
Ive not tryed it yet Jeff, ill pop over BnQ tomorrow for a olive and try and remove it. Wish me luck lol
Old Dec 14, 2013 | 08:24 AM
cozzy jeff's Avatar
cozzy jeff
If its holding you up just leave the lines attached and remove the fuel rail from the manifold.
3doorcozmess
Aug 21, 2015 11:17 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
RSMK4TURBO
Aug 13, 2015 08:06 AM
muffster
Aug 12, 2015 08:14 PM
Bosch
Aug 4, 2015 05:14 PM
