Mk3 2.5 mondeo electrical????
HI, WENT AND CHANGED NUMBER 97 FUSE IN GLOVE COMPARTMENT YESTERDAY AND WHEN I WENT TO START THE CAR THE DISPLAYS ON THE CLOCKS SHOWED FOR A FEW SECONDS AND THEN SHOWED DOTTED LINES GOING THROUGH THEM AND THE CAR WONT EVEN START. HAVE CHECKED ALL FUSES IN GLOVE COMPARTMENT AGAIN AND THE FUSES UNDER BONNET BUT THEY ALL LOOK FINE. CAN ANYONE HELP.
Normally --- shows on the instruments if it's lost communication between modules, or a 5 volt reference sensor has shorted.
Sure you haven't knocked any plugs out of the fuse box or disturbed anything when changing fuses?
5v reference sensors are all over the engine.
Throttle sensor, air mass meter, well, most sensors...
If it's not something you've knowingly disturbed, it needs diagnostics doing to point to an issue.
THANKS FOR THE ADVICE, AM GOING TO TRY AND GET A DIAGNOSTIC DONE ONE DAY THIS WEEK HOPEFULLY, WILL LET YOU KNOW THE OUTCOME, ELECTRICS ARE A NIGHTMARE, MECHANICS AM GOOD WITH BUT THIS HAS BAFFLED ME.
mk3ste
Oct 17, 2021 10:09 AM
Steve Escos
Oct 1, 2015 06:57 AM
