Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Help with focus turbo conversion
Old Dec 7, 2013 | 04:43 PM
mr noisy's Avatar
mr noisy
Default Help with focus turbo conversion
Hello all
Ive just bought a mk1 ford focus 3 door in black and its running the std 1.8 silver top engine which runs 100% fine, its had the four branch manifold fitted along with decat/stainless system & the large throttle body conversion
Now this is fine but it does not owe me much and wanna go down the route of turbo the old girl up, now ive seen many mixed things on this but im not after huge power so low boost pressure is fine, As I have said its being done on a budget so what is there I can do ?? I have seen the exhaust manifold plates so I can bolt a CVH manifold onto the zetec engine then run the T3 turbo but will the uprated inlet side be ok ??
All comments welcome as I know I need to get fuel in there too
cheeRS
Old Dec 14, 2013 | 05:53 PM
xtopiana's Avatar
xtopiana
I haven't done this myself but as an owner of the exact same car I have considered it and done some research into it.
For the time and effort i'm sure you realise that it really isn't worth it as the 1.8 as standard puts out 112bhp. Let's say you are aiming for around a 50bhp or more power gain. Well as ST170 will provide that perfectly and in N/A form. You can pick them up for £1500 and use the money from selling yours to go towards it. It runs 170bhp from the factory and with simple bolt on mods and a remap can be good for 200bhp. So that's nearly 2x as much as your 1.8 - something not realistically achievable by a simple low pressure t/c.
However i'm sure you have been told this many times and as such I will give you three bits of advice.
1. Buy a good quality pre-made t/c manifold so you don;t have to make one. There are loads out there just don't buy a cheap one off eBay that will send shards into your turbo.
2. Watch the MCM turbo conversion vid. Much of it applies to any t/c and is very in depth and descriptive.
3. Don't think to yourself that this will cost less that £1500+...
:L
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
