Horrid noise
Old Dec 6, 2013 | 06:31 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Default Horrid noise
Got a real horrid clonking noise coming from the rear end of my saff when swinging it round corners? Would the rear beam bushes cause this?
Old Dec 6, 2013 | 07:42 PM
Get the car jacked up and check all the bushes. Check the rear diff mount and the prop shaft uj.s.
Old Dec 6, 2013 | 07:59 PM
gingerturbo
Ill stick it on the ramp in the morning, I have bin abusing it lately and its not poly'd yet, the noise sounded as if its bottoming out and the shaft is touching?
Old Dec 6, 2013 | 09:10 PM
teamfatboy's Avatar
teamfatboy
Frog Tosser
I thought this was a 1 direction thread!!
Old Dec 7, 2013 | 06:05 AM
gingerturbo
Haha it's a horrid noise bits its not that bad
Old Dec 7, 2013 | 08:51 AM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Diff and box mounts!
Old Dec 7, 2013 | 01:19 PM
Marc sierra's Avatar
Marc sierra
The CV joint maybe?
Old Dec 7, 2013 | 01:26 PM
dojj's Avatar
dojj
Resident Wrestling Legend
cv's would clonk
or it could be the exhaust hitting something
Old Dec 7, 2013 | 02:31 PM
gingerturbo
Cvs would do it every time I turn, I've only noticed it if I really swing it round a corner, could be diff mount as its starting to float a bit when cornering?
Old Dec 7, 2013 | 04:37 PM
Get a poly diff mount on then go out and chuck the car about and you will notice the difference.
Old Dec 7, 2013 | 04:41 PM
gingerturbo
I'm getting the rear set after Xmas and are the diff mounts the same I.e saff,3dr,escos, 2wd,4x4
Old Dec 7, 2013 | 05:05 PM
Steve the Plumber
Mine made real bad noises when doing trackdays, I changed the diff and box mounts which that problem!
Old Dec 7, 2013 | 05:15 PM
gingerturbo
Cheers Steve
gingeRS
17
Oct 2, 2015 09:42 AM
Botts
Sep 22, 2015 02:04 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
rsturbo27
Sep 5, 2015 05:08 PM
