Ford Range This section is for other models in the Ford range.
Battery light stays on Ford Fusion 2006
Old Dec 5, 2013 | 12:40 PM
kennymcd's Avatar
kennymcd
Default Battery light stays on Ford Fusion 2006
Hi, I have a Ford Fusion 2006. The battery light stays on when the engine is running. I have checked the charging voltage and it is 13.5 volts. Anyone any idea what is keeping this light on. Thanks
Old Dec 5, 2013 | 12:58 PM
martysmartie's Avatar
martysmartie
Check the 3 pin multiplug connector is not broken that connects to the alternator has not broken.
There are many reasons as it's electronically controlled, but the above is a common one.
Martin
CCNA
Old Dec 5, 2013 | 06:11 PM
GVK.'s Avatar
GVK.
Does the light go out once the car is started, and then come back on about 20-25secs later or does it just stay on once car is started?
Old Dec 5, 2013 | 09:31 PM
kennymcd's Avatar
kennymcd
Default Battery light staying on
It stays on once the car is started!
Old Dec 5, 2013 | 09:44 PM
GVK.'s Avatar
GVK.
Wasn't a trick question
Is it diesel or petrol?
https://passionford.com/forum/ford-m...ery-light.html
Old Dec 5, 2013 | 11:19 PM
kennymcd's Avatar
kennymcd
Its a Ford Fusion 2006 Petrol!
Old Dec 5, 2013 | 11:59 PM
GVK.'s Avatar
GVK.
Refer to linked thread.
xr_craig
Aug 7, 2015 06:00 PM
